11-06-2017, 05:49 PM | #1 |
Rock Crawler Join Date: Apr 2017 Location: US
| TRX4 receiver channel questions
Okay I meant to finally sit down and install my new Savox Servo that has been sitting in my parts box. Nothing wrong with the stock Servo other than I wanted to have more torque. Before closing up everything on the truck I wanted to make sure everything operated okay. After plugging in the new servo I noticed it was not working at all no buzzing no turning at all. I had to install an extension lead for the servo so I played around with that for a bit. I also tried plugging it into my slash that has a Savox Servo and still does not work. So I plugged it back into the trx4 and this time I plugged it into the first slot in to channel one and it works at should. For the short little Drive I did it seem like it worked just fine. But for some reason it would not operate on the second slot on Channel 1. I even called Traxxas today to confirm about the two slots on Channel 1 and they told me what I kind of thought anyway that the two slots are for the steering as if you were to run dual servos or to run a light or accessories with to operate with the steering. They could not confirm that I needed a bec since they do not make them. I understand that it's an after-market thing and I'm fine with that. But you do have to love their customer service and how quick there to answer a question and usually seem to have an answer. So my question is has anybody else experienced this plugging it into the first lot into Channel 1 or having to run a bec because of it? I'm assuming since I can get it to operate on channel one and if it does not seem to glitch out that I should be okay to run it if it starts to glitch out I guess I can always look into a bed. |
11-08-2017, 07:37 PM | #2 |
| Re: TRX4 receiver channel questions
The steering servo plugs into the first channel 1 connector, the optional Traxxas light module piugs into the second channel 1 connector. Don't ask me what the difference between them is.
