11-15-2017, 02:37 AM | #1 |
Rock Stacker Join Date: Sep 2011 Location: UK
| returnee
I had given up on this wonderfull hobby but then along came a Traxxas TRX-4 with a Defender body on it and I was smitten again and with being British I love the Defender body on the truck, the only modifications so far are adding a winch, changed the steering servo and the TRX light kit, going to add the brass portal covers and other brass parts when funds allow to add more weight lower down also change the stock tyres and rims for heavier rims again when funds allow Last edited by BREL; 11-15-2017 at 11:51 AM. |
11-15-2017, 01:22 PM | #2 |
Newbie Join Date: Nov 2017 Location: Canada
| Re: returnee
I also love my trx4 and the defender body, the winch upgrade is a must to replace the plastic imitation, as the lights are, imo, also a must. I added camel trophy stamps, I will install the diamond plate to protect the hood, added mud pads, brass weight will be added when it gets here. Envoyé de mon LG-H831 en utilisant Tapatalk |
11-15-2017, 05:49 PM | #3 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: returnee
when it comes time you add the brass portal cover weights, i recommend the ones from SSD. i put them on all 4 corners and the fit and finish is perfect, huge improvement. recent adds for mine was the weights and adding proline dual stage foams to the hyrax tires. |
11-19-2017, 03:39 PM | #4 |
| Re: returnee
got a set of GPM brass portal covers on order the should be at mine next week some time
01-01-2018, 05:28 AM | #5 |
| Re: returnee |
01-01-2018, 07:27 AM | #6 |
| Re: returnee
Just be careful when you start to add a lot a brass parts, you want the weight in key areas first. If you add too much weight thats sprung you can actually start decreasing it's performance. Another way to keep the weight down low is go with some Gmade steelies. These weigh 135 grams per wheel and while it's rotating mass it is down low and will help a lot. Plus they look scale as frig ! |
01-04-2018, 02:30 PM | #7 | |
| Re: returnee Quote:
01-22-2018, 10:11 PM | #8 |
| Re: returnee
single stage foams now fitted to the tires, also on order are the Samix TRX-4 Brass lower shock / suspension mounts and TRX-4 Samix brass knuckle with the TRX-4 Samix brass hub carrier, these should add about 200g (unsprung weight) to the front axle of the TRX4, less the weight of the plastic parts that have to be removed to fit the bass parts
03-21-2018, 12:34 AM | #9 |
| Re: returnee Last edited by BREL; 01-12-2020 at 06:34 AM. |
