02-23-2018, 11:24 AM | #21 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Re: best knuckle weights?
Thanks for noticing that, and I like STRC, now I know to stay away from those chubs. (When I get one) Soon, hopefully soon !
02-23-2018, 12:59 PM | #22 |
Sure and yes more is generally better (I'm sure there's too much at some point lol) it helps the edges of front tires dig in and pull up over steep/difficult climbs, also as you steer it drops the front ride height helping weight transfer. Yes, more caster is more likely to cause link and/or shock, steering linkage, panhard clearance problems. I'd say 20* is about max you'd want, so G-Made must have done some homework. |
02-23-2018, 02:23 PM | #23 |
Hey thanks Nate |
02-23-2018, 04:43 PM | #24 |
You're welcome Casey! |
02-24-2018, 10:51 AM | #25 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
I agree with Nate. Given the option I'd go with 20 degrees, keeping in mind it may change the high speed handling if that's how the rig is used. I think the low speed crawling benefits (especially on climbing ledges) are well worth it.
02-25-2018, 01:09 PM | #26 |
It would be very helpful if we could get the various manufacturers to publish the caster numbers of their aftermarket TRX4 C-hubs.
02-04-2019, 10:06 PM | #27 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Good read and wonderful guys here. |
02-05-2019, 08:21 AM | #28 |
Newbie Join Date: Jan 2019 Location: Jax
Any thoughts on the Locked Up RC steel parts? TRX-4 Black Steel C Hubs Seems like at least for the C's they would be more durable vs. rocks and are slightly heavier than the ones posted above. I have been considering that set up for a white now. |
02-05-2019, 09:01 AM | #29 | |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
| Re: best knuckle weights? Quote:
I've got 'em on both of my TRX4's ( Bronco and Defender). Absolutely top-shelf product. Flawless fitment with stock TRX4 parts and it gets that nice heavy weight right down as low as you can go. I've beat on 'em pretty good at this point and they are as durable as it gets. Highly recommend. | |
best knuckle weights? - Similar Threads | ||||
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
VP Knuckle Weights | mgauger | Axial XR10 | 7 | 11-09-2011 10:58 AM |
Knuckle weights? | EvilTwin v2 | Scale Comp Rules | 21 | 09-09-2011 06:21 PM |
