01-01-2018, 11:48 AM | #41 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Anyone competing with a TRX-4?
i changed stock with the silver progressive springs out of the hot racing hd rally tune spring Set for the savage xs (ssxs68mr14) i bought originally for my yeti icons. so basically you could use any spring with 13mm inner diameter and choose the length you like, these are 70mm. |
01-01-2018, 11:57 AM | #42 |
Pebble Pounder Join Date: Sep 2009 Location: Airdrie, Alberta
I have complete spring rate lineups for Team Associated's older 1/10 trucks and buggies which are the same diameter. I'll have to play around with some different shock setups.
01-01-2018, 04:41 PM | #43 | |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: Anyone competing with a TRX-4? Quote:
They have them, 4 optional rates. I seen them in the accessories section a couple weeks ago. $6.00 a pair Standard spring rates no stripe .45 green stripe .54 Option spring rates yellow stripe .22 white stripe .30 orange stripe .39 blue stripe .61 | |
05-22-2018, 11:04 PM | #44 |
Pebble Pounder Join Date: Jul 2016 Location: Ne pa
My class 1 jeep trx on the rocks
05-24-2018, 09:51 AM | #45 |
Rock Stacker Join Date: Sep 2017 Location: in a RV
| Re: Anyone competing with a TRX-4? |
05-25-2018, 08:35 PM | #46 |
Xtraspeed body from a main and 295 wb I had to cut the roof in 3 pieces and throw out the middle piece and cut the body in half and add about 20 mm built the cage from 5/32 music wire Have 1 that is almost identical for class 2 also Last edited by solo1; 05-25-2018 at 08:44 PM. |
05-25-2018, 08:39 PM | #47 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
I'm competing in the Calgary Call to Crawl series with my TRX4. |
05-25-2018, 09:10 PM | #48 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Wow, that’s a fantastic rex you have there tossed man. Engine detail is next level.
06-18-2018, 04:14 PM | #49 |
My class 2 jeep trx on the rocks
06-19-2018, 05:23 AM | #50 | |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
Sent from my LG-H870DS using Tapatalk | |
08-13-2018, 08:52 AM | #51 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
So is there any new TRX comp builds out there? Have run my TRX in c2 at 4 comps so far, and is quite pleased with the performance. But it needs to loose some weight. Got about 220g brass on the front axle and 140g on rear axle. I’ve got a light weight body and have shortend the WB to 320. Now I’m looking for titanium links for 313 WB , and a lighter chassis. |
08-15-2018, 02:49 PM | #52 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
My sport will eventually be a class 2 comp rig and maybe change tires to make it a class 1 rig. Plan for interior and some other goodies to get as many points as possible. |
08-18-2018, 10:51 AM | #53 |
Rock Stacker Join Date: May 2018 Location: northern illinois
Heading to my first comp ever tomorrow with mine Sent from my SM-G950U using Tapatalk |
09-28-2018, 12:40 PM | #54 |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
09-28-2018, 01:38 PM | #55 |
Proline 85 hilux body. Ssd winch bumber. Thx Sent from my SM-G950U using Tapatalk |
09-28-2018, 01:48 PM | #56 | |
PARTS FOR TRX-4Rock Shield Winch Bumper for TRX-4 / SCX10 II and this: https://www.prolineracing.com/bodies...dy-cab-bed.asp I notice the wheelbase for that body is not the 12.8 - did you have to make many adjustments to get it to fit like that? | |
09-28-2018, 02:26 PM | #57 |
I run a bronco based trx4 so the body fit fine. Had to order a locked lockedup rc front bumper mount to get the front bumper where I wanted it Sent from my SM-G950U using Tapatalk |
10-23-2018, 07:59 AM | #58 |
Newbie Join Date: Aug 2018 Location: Aurora
Anyone get a trx4 able to compete in a class 1? Sent from my iPhone using Tapatalk |
10-23-2018, 05:21 PM | #59 |
10-23-2018, 06:12 PM | #60 |
Newbie Join Date: Jun 2015 Location: Littleton
Here's my Defender based rig after the most recent round of mods. Brass bumper/servo mounts Brass portal covers Brass c hubs Brass hexes Brass link mounts Castle 10a bec 25kg servo relocated and powered directly from bec to avoid burning out micro servos ESC relocated Proline Impulse beadlocks, dual stage foams, and Hyrax Predator Tires She is going to her first comp this weekend. Got into scale crawling late in the season but will be all over it next year for sure. |
Anyone competing with a TRX-4? - Similar Threads | ||||
Competing questions | Heavychevy06 | Newbie General | 3 | 08-28-2012 11:50 AM |
How do I start competing? | irokcrawl | Newbie General | 2 | 05-03-2012 06:46 AM |
Anyone interested in competing in Manitoba? | Evandiego | North Dakota | 3 | 04-09-2011 08:21 PM |
anyone competing in the USRCCA Nationals? | ddiaz10240 | Chit Chat | 3 | 07-13-2006 08:20 AM |
