Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Power the Traxxas Rock Lights direct from rx
Old 12-09-2017, 04:44 AM   #1
Default Power the Traxxas Rock Lights direct from rx
I gave up at soldering smd led which are only .5mm sq. i'm too old for this
so i got the traxxas 8026 rock lights. which i want to power over a switch direct from the rx 6V . The power unit from traxxas is delivering 3v 500 mAh.
The question i run into is which resistor i have to use to bring down the 6V to the needed 3V. I have read the heyok thread in the electronic section but i'm lacking the information of the resistance of the rocklights. so far i found out that the 8 Lights are wired in series and on board where the smd led are mounted has the id SA17012 REV1.
My thoughts for the Calculation are 8 * 20 mA (like normal LED not sure here) = 160 mA so droping 3v will give 3/0.16 = 18.75 Ohm = 20 Ohm resistor or should i calculate with the 500 mA the power unit is spec which will give 10 Ohm. Has any one the missing spec? or any advise would be appreciated.
magic_yeti is offline   Reply With Quote
Old 12-12-2017, 12:55 PM   #2
Cool Re: Power the Traxxas Rock Lights direct from rx
Electrician by trade here. It's taken me a little time to remember some bits about Ohms law and series circuits to get back to you, but I think I can help. It's important that your able to understand everything I'm about to lay out exactly. It takes a shockingly small amount of current or amperage to do damage to or kill a person, so if anything is unclear get clarification before continuing to wire this up. Danger warnings aside, lets begin.
We can figure the theoretical max resistance of all the lights Traxxas runs off their power supply using Ohms Law. We're solving for resistance, so R=V (volts)/I (amps). They state it runs 3v and .5A, so our equation looks like: 3/.5=6 ohms. Remember, that's the maximum resistance that any of the lights could be.
How do we know that? If we overloaded the power supply, the lights wouldn't work obviously. But there's another electrical rule at play here, Parallel circuits. For those lights to all glow evenly, they all need 3 volts. So the power supply is set up to supply all power to each load at once, instead of bringing the current flow through the light bar, then the body lights, etc. Its set up something like this. So each light set gets 3 volts, but they can only use a portion of the available .5 amps.
Also in parallel circuits, the more parallel resisters (in this case, led light sets) are in a circuit, the lower the total resistance of the circuit. It makes sense, there are more paths for the current to take, so it has an easier time flowing. That means your light bar can't be more than 6 ohms resistance.
Now we need to find the right sized resistor to hook up your lights and not fry them.
I don't remember if you said you're using the stock Traxxas ESC or a replacement, so I don't know how many volts or amps your receiver is getting. I'll calculate for the Traxxas ESC and show my work; if you don't use the stock ESC or use a BEC, you should be able to plug the right numbers in and get the answers you'd need. I already did the research on the stock ESC while looking into replacing my steering servo. The stock setup supplies the receiver with 6V,1A; exactly half the light power supply is rated for.
Realize now that this is another parallel circuit scenario, so all the servos and the receiver share that 1 amp to function. So then lets not worry about getting .5 amps. (If it was designed well, Traxxas should have the light power supply be able to supply more amperage than the lights would need anyway.) Instead, lets get 3 volts for the light bar. To do that, we need to know about Series circuits.
Unlike Parallel circuits where voltage is a constant and amperage is dropped across loads, in Series circuits amperage is a constant and voltage drops. We can use this to get the voltage right for your light bar, but it will mean cutting one of the leads and soldering in a resistor.
To figure this at 6v is pretty easy. In any series circuit, the voltage dropped across all the loads adds to the total voltage of the circuit. We've got two loads, the first is our LED bar and the second is our mystery resistor. To split the voltage in half, we'd need a resistor that matched our LED bar as closely as possible, so a 6 ohm resistor. Easy right?
But I promised to show work, so let's look at a 7.4 volt situation. In that case we know we want 3 volts at our light bar, which should have 6 ohms resistance and be flowing .5 amps. From that we know two things about the mystery resistor: 1) we want it to take the remaining 4.4 volts from the supply, and 2) since it's in a series circuit, it's going to be using the same .5 amps as the LED bar. So we solve for resistance again: 4.4v/0.5a = 8.8 ohms resistance. So that resistor would need to be 8.8 ohms if it's getting 7.4 volts from the receiver.
WAIT!! We're not done yet! There's two more things we need to check: How much wattage will the resistors need to dissipate, and is our solution realistic?
Electricity is always trying to do work, so the voltage on our mystery resistor isn't just disappearing. The resistor is using that voltage to produce heat, which we can calculate as watts (P). If our resistors aren't able to dissipate all theheat they create the will (literally) burn up and fail. I'm going to use the best known numbers we have to figure the wattage our resistors will be creating, the volts we're trying to apply to them and the resistance itself. The equation is: watts (P) = V^2 (Voltage squared)/ R (ohms). For our 6v resistor, that looks like: 3^2/6 = 1.5 watts. For our 7.4v resistor, its: 4.4^2/8.8 = 2.2 watts.
The last thing to check is the realism of our solution. If we use the 7.4v solution, we should be ok. Pretty much any BEC or ESC that could supply that voltage could spare the .5a we figured we'll need. But the stock 6v solution is likely to cause problems. The stock BEC only gives us 1a after all, so this lighting setup would starve the receiver and servos of power and cause radio glitches, poor servo performance, maybe even ruin a servo. Basically the stock BEC is weak and easily overloaded, which is probably why there's a separate light power supply to begin with.
The stock thing is still possible, IF the resistance of the LED bar is different from what I calculated here. If it's got a lower resistance, it could use less amperage and then the whole thing is workable again. We'd need to plug our new numbers into all the equations again, but it's still plausible.
I hope this novel of a post helps.
Dman07 is offline   Reply With Quote
Old 12-14-2017, 03:55 AM   #3
Default Re: Power the Traxxas Rock Lights direct from rx
Tanks for your answer. i think cause i'm still using (till it breaks or budget...) the stock esc. found a solution which runs direct from the lipo (2-3S)
found a dc/dc converter on fleabay which has adjustable output:
just 2$ for 4
In: DC 4.75V-23V, Out: DC 1.0V-17V (adjustable), Amp: 1,8A (3A MAX), Efficiency 96%, Size: 7mm * 11mm * 3.8mm (L * W * H)
https://www.ebay.de/itm/4X-Mini-3A-DC-DC-Konverter-Step-Down-Buck-Netzteil-3V5V-16V-MP2307-Chip-RA/173013230482?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Old 01-20-2018, 01:38 PM   #4
my mini converter arrived and i had time ... waterproofed it with seal spray soldered the cables
works perfect, adj. output to 3.0V and a little custom work gives a dual 3 V output
the blue cable on the rock lights is + black - and had to be swapped to fit standard
Power the Traxxas Rock Lights direct from rx - Similar Threads
Adding the lights and rock lights to a TRX-4 MikeMontgomery1970 Traxxas TRX-4 6 09-09-2017 10:15 PM
12v lights and water...direct lipo connection CoolRunning Electronics 5 04-30-2017 08:10 PM
12v LED lights, how to power them Vengeance Electronics 2 08-04-2016 09:34 PM
Will these batteries power lights? TURBOxN3RD Newbie General 3 06-23-2015 04:53 PM
traxxas big bores direct fit? justintime Axial AX-10 Scorpion 10 11-28-2007 01:12 AM
