12-12-2017, 11:33 AM | #1 |
Newbie Join Date: Sep 2017 Location: westchester
| Broken stock Motor
Anyone else break the built in fan on the stock motor? Apparently i was able to, and it appears it decided to melt in doing so. Managed to pull all of this out from the motor. Thinking i will run it until it completely shits the bucket then upgrade. being new the the RC world and crawlers especially, i went ahead and did some research as far as what designations mean when it comes to 21 turn motors vs higher/lower turns. So ive gotten a good idea as to where i plan to go with that. However for ESC's is it "mandatory" to upgrade that as well? or can i stick it out with the stock one for now? |
12-12-2017, 12:39 PM | #2 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: Broken stock Motor
You don't have to switch ESCs unless you were switching to a brushless motor, in which case you'd need a brushless capable ESC. Some ESCs like the Hobbywing 1080 (brushed only) and Castle Mamba (Brushed/Brushless/Sensored Brushless) have extra tuning for drag brake, reverse speed, etc. for fine tuning.
12-12-2017, 04:06 PM | #3 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
Also don't be going lower than a 21 turn motor with that wax as you'll burn it out !
12-12-2017, 08:16 PM | #4 |
Rock Stacker Join Date: Jan 2014 Location: online
Traxxas motors and lipo's are total garbage As im sure most the other electronics are junk too |
12-13-2017, 12:39 PM | #5 |
Yeah the Traxxas motor isn't junk (their Batteries are though), but If you wanted something different the Holmes 550 sealed can is a great alternative, I ran one for a bit in my TRX-4 until I gave in to my urges to upgrade further.
12-13-2017, 09:13 PM | #6 |
Newbie Join Date: Nov 2017 Location: In a house
Ohh broken parts....good time for a Castle 2280 and Mamba X.
12-14-2017, 07:01 AM | #7 |
I looked into getting another traxxas motor just for the ease of it and since i do a fair amount of water crossings i figured a stock cheap motor i wont care much about would be good. however the brushed 550 motors aren't expensive at all. May just go with a holmes model as they too are inexpensive.
Broken stock Motor - Similar Threads | ||||
Two Broken Stock Axles | OkinawaCrawler | Axial RR10 Bomber | 16 | 03-10-2017 03:18 AM |
Broken motor tab: Repairable? - SOLVED! | LAV25 | Electronics | 5 | 08-23-2011 08:09 PM |
Broken motor brush | AdverseCity | Electronics | 16 | 08-12-2010 11:02 AM |
fix that broken stock wheel | bennett-racing | General Crawlers | 1 | 01-16-2006 11:24 AM |
