12-24-2017, 08:10 PM | #41 |
Pebble Pounder Join Date: Aug 2017 Location: US
| Re: TRX 4 Body Bashing, The cutting has begun...
What follows its a complete walk around of the finished body bash. Or a breach birth is what I call it... hehe. Didn't come easy. Worth every hour spent on it tho. And only one way to get one. Start bashing. Enjoy! Sent from my SM-G950U1 using Tapatalk Last edited by sammyha; 12-24-2017 at 08:41 PM. |
12-24-2017, 08:42 PM | #42 |
Some final details... Sent from my SM-G950U1 using Tapatalk |
12-24-2017, 08:47 PM | #43 |
Not done yet either. Figured if this turned out ok it deserves some performance upgrades. Stay tuned... Sent from my SM-G950U1 using Tapatalk Last edited by sammyha; 12-24-2017 at 11:56 PM. |
12-24-2017, 09:13 PM | #44 |
Ever see this? Sent from my SM-G950U1 using Tapatalk |
12-24-2017, 09:15 PM | #45 |
Not trick photography... This a few moments later... Pit Bull Alien Kompound tires are that sticky. Sent from my SM-G950U1 using Tapatalk |
12-25-2017, 01:01 AM | #46 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: TRX 4 Body Bashing, The cutting has begun... |
12-26-2017, 07:53 AM | #47 |
Rock Crawler Join Date: Apr 2017 Location: US
Wow what a great project. Looks great. You put a lot of time into it for sure. Wish I had that kind of time.
12-26-2017, 08:34 AM | #48 | |
| Re: TRX 4 Body Bashing, The cutting has begun... Quote:
Sent from my SM-G950U1 using Tapatalk | |
12-26-2017, 10:23 AM | #49 |
Newbie Join Date: Dec 2017 Location: Oakland
Awesome job! Traxxas should hit you up for secondary body ideas. With the rise in popularity of the SUV truck category in 1:1 world (see news hype on the Jeep JL Scrambler) I bet people would dig the Land Rover Truck concept like I do. Great work and thanks for bringing us along on the journey! Sent from my iPhone using Tapatalk |
12-26-2017, 04:21 PM | #50 | |
As always, people see an idea and add new twists. Like my exo cage and roof rack mod. And how the cut layout eliminates the upper windows and hides the seams. Glad you're enjoying the thread, maybe there will be some more cutting taking place (by some other bashers, I'm done). It's a big job but this could be followed step by step I think. With some more different twists I'm sure. Sent from my SM-G950U1 using Tapatalk Last edited by sammyha; 12-27-2017 at 12:06 AM. | |
12-26-2017, 04:23 PM | #51 |
Christmas is over and the mailman delivered! Sent from my SM-G950U1 using Tapatalk |
12-26-2017, 04:29 PM | #52 |
Weights on all four corners. My beadlocks came today, but didn't fit with these Hot Racing weights. Should have read the tire/ weight fitment thread... But, I already knew these Alientacs I had on my Barrage fit... So... I get the pleasure of swapping out 8 tires. I'll put the wheels that came today on the Barrage. There's 128 screws on these Alientacs... Sent from my SM-G950U1 using Tapatalk Last edited by sammyha; 02-07-2018 at 01:45 PM. |
12-26-2017, 04:31 PM | #53 |
Halfway home... hehe. Here's a reward look at my hard work. On to the other side... Sent from my SM-G950U1 using Tapatalk |
12-26-2017, 07:46 PM | #54 |
It's gonna be awhile weather wise before I can do a true test on my rock course to get a known comparison. Knocked some top weight off with this body mod, added these Hot Racing brass weights and Pit Bull tires. Either way it should look better doing it... Sent from my SM-G950U1 using Tapatalk |
12-26-2017, 09:52 PM | #55 |
Here's a YouTube link to a short indoor crawl on my single rail section. https://youtu.be/LsaJzHBzEDc Sent from my SM-G950U1 using Tapatalk |
12-27-2017, 12:42 AM | #56 |
I apologise up front for getting into this with crazy detail. But I'm sure some guys are wrestling with mounting these 3D printed hinges... The hinges and screws are SO tiny! Sent from my SM-G950U1 using Tapatalk Last edited by sammyha; 12-27-2017 at 01:08 AM. |
12-27-2017, 12:51 AM | #57 |
Being a machinist by trade means you're anal on details. You have to be anal to be good at it. Ok... The holes in the hinges are printed to the self tapping size for the screws, .031, and the screws measure .041 in diameter. So if you have a drill set like this use two drills, .031 and .039 diameter. I'll explain why to use the .039 diameter drill later. Sent from my SM-G950U1 using Tapatalk Last edited by sammyha; 12-27-2017 at 12:59 AM. |
12-27-2017, 12:54 AM | #58 |
It's easy enough to hold a hinge in place and drill one hole. Good luck drilling the other holes without the hinge moving. I'm using a pin vise. Basically hand drilling the holes. Drill one .031 hole thru the body. Sent from my SM-G950U1 using Tapatalk Last edited by sammyha; 12-27-2017 at 01:01 AM. |
12-27-2017, 12:56 AM | #59 |
Next, run a screw in the hinge, same hole you drilled thru the body. Have just the tip sticking thru. It will screw in tight and stay there. Sent from my SM-G950U1 using Tapatalk |
12-27-2017, 01:05 AM | #60 |
Place the hinge back on the body with the tip of the screw in the hole. With a little pressure from a screw driver it won't move. Now your finger is out of the way and you have room to drill the other holes Sent from my SM-G950U1 using Tapatalk |
TRX 4 Body Bashing, The cutting has begun... - Similar Threads | ||||
Trx-4 Body weights. | clm | Traxxas TRX-4 | 4 | 08-25-2017 04:55 PM |
TRX-4 Body options | Zippy1 | Newbie General | 2 | 08-22-2017 01:23 AM |
Cutting trx tires | dittohead | Traxxas TRX-4 | 2 | 08-10-2017 01:13 AM |
TRX-4 plus Axial FC Body. | AggressorBLUE | Traxxas TRX-4 | 5 | 05-17-2017 08:45 AM |
