03-20-2019, 06:24 PM | #21 |
| Re: End point adjuster for Diff Servos
This new end point adjuster is only needed if you remove the servo savers. Lack of end point adjustment is also why the servo savers are installed in the first place. I currently have 5 TRX4s and out of the 15 micro servos across my fleet I have had to replace exactly one servo and that one was my mistake. That said, I like this for a number of reasons not the least of which is the inability to adjust them easily from the stock TX but I'm wondering if these could be mounted side by side in a block of three and then placed inside a waterproof box.
03-21-2019, 05:36 AM | #22 | |
| Re: End point adjuster for Diff Servos Quote:
Yes, it will work with the stock radio set up, or anything that outputs a two position servo signal. | |
End point adjuster for Diff Servos - Similar Threads | ||||
mt4 raido end point help | vito | Electronics | 6 | 05-29-2018 12:57 AM |
Servo EPA end point adjuster / controller / limiter | wantAsummit | Electronics | 15 | 08-10-2010 03:13 PM |
End point adjustments | C_Money | Newbie General | 3 | 01-04-2010 01:01 AM |
End Point Help | mikegigabyte | Electronics | 3 | 12-18-2009 07:42 PM |
End Point Adjustments | DANALLY | Electronics | 5 | 08-29-2007 06:23 AM |
