02-20-2018, 12:39 PM | #1 |
| End point adjuster for two position channels
I came up with an idea this morning and built a new part. Please let me know what you think. Thanks for your time, Al Last edited by heyok; 02-21-2018 at 04:06 PM. |
02-20-2018, 02:05 PM | #2 |
Newbie Join Date: Jan 2018 Location: The Netherlands
| Re: End point adjuster for Diff Servos
Want 3 |
02-20-2018, 02:08 PM | #3 |
| Re: End point adjuster for Diff Servos |
02-20-2018, 02:30 PM | #4 |
A question for you guys: Does the transmission shifter servo also need adjustable end points because the servos are failing? |
02-20-2018, 03:23 PM | #5 | |
Pebble Pounder Join Date: Oct 2016 Location: Philly Area
| Re: End point adjuster for Diff Servos Quote:
That said, is this end-point adjuster water proof? | |
02-20-2018, 03:27 PM | #6 | |
The controller isn't waterproof. The two pots (rotary controls) could get water inside them. The rest of the controller is all sealed up with Plasti Dip and then covered with heat shrink. If it were in my rig, I'd set the controls, then smear some silicone or Plasti Dip over them to seal them up. I don't know of a way to seal them up before I ship them out because they will need adjustment. | |
02-20-2018, 03:29 PM | #7 | |
Rock Stacker Join Date: Jan 2018 Location: Madison
Can the internals be conformal coated to waterproof them? | |
02-20-2018, 03:30 PM | #8 |
02-21-2018, 04:04 PM | #9 |
Yeah this is an Ok, I mean great idea, well done!
02-21-2018, 04:09 PM | #10 |
02-21-2018, 04:19 PM | #11 | |
I ordered one just for the 2 speed, I already got the dual winch controller with end points on the way to take care of the diff lockers. | |
02-21-2018, 04:21 PM | #12 |
Thanks for the order! I appreciate the work.
02-21-2018, 06:54 PM | #13 |
Pebble Pounder Join Date: Mar 2017 Location: Southern Maine
Very nice...innovative..i am so used to epa's vs mechanical centering.
02-22-2018, 02:31 PM | #14 |
Very cool.
03-20-2019, 02:32 PM | #15 |
Newbie Join Date: Mar 2019 Location: Cumming
anyone setup their TRX4 with these yet?
03-20-2019, 03:08 PM | #16 |
Rock Stacker Join Date: Feb 2019 Location: Los Angeles
Curious as well. I may grab a set because I don’t want to call it quits on the locking/unlocking diffs but the stock setup is too sloppy and I’m burning servos left and right. I really want to do full size servos and this to help mitigate.
03-20-2019, 03:12 PM | #17 |
I'm happy to make them for you! Are the diffs the only servos that are giving you trouble or does the tranny servo also need help? |
03-20-2019, 05:52 PM | #18 | |
Do you have pictures of this setup if you're running them currently? Works with stock TQi setup? Getting rid of or finding a better version of those saggy servo savers that come factory has been on the list for a while now. | |
03-20-2019, 05:55 PM | #19 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Or you could convert it to spool for maintenance free.
03-20-2019, 06:15 PM | #20 |
| Re: End point adjuster for Diff Servos I like the way the truck handles with them open for trailing. It's part of the scale fun to trail open and close them up as you need the grip or hit a line of rocks. I'm willing to try a few more things (this adjuster, and maybe even full size servos if I can find someone to print the mount) before I give in and go spool. |
End point adjuster for Diff Servos - Similar Threads | ||||
mt4 raido end point help | vito | Electronics | 6 | 05-29-2018 12:57 AM |
Servo EPA end point adjuster / controller / limiter | wantAsummit | Electronics | 15 | 08-10-2010 03:13 PM |
End point adjustments | C_Money | Newbie General | 3 | 01-04-2010 01:01 AM |
End Point Help | mikegigabyte | Electronics | 3 | 12-18-2009 07:42 PM |
End Point Adjustments | DANALLY | Electronics | 5 | 08-29-2007 06:23 AM |
