Mamba x servos question I’m installing a mamba x and had intensions on turning the esc’s bec voltage to 8 volts. I assume this means my shifting servos won’t like this. Am I stuck using an external bec? |
Re: Mamba x servos question Quote:
Re: Mamba x servos question I'm running a Mamba X in my TRX4 set at 6v and everything works great. Not sure I understand why you would need 8v. |
Re: Mamba x servos question My steering servo takes up to 8.4v. Superior Hobby Kingmax BLS3512SP 71g 35kg.cm,digital,steel gears standard servo for 50-150CC gas engine, 1/5 car https://www.amazon.com/dp/B0778JMYJ5..._usWKAbCBFYJ5M |
Re: Mamba x servos question It looks like a bec is inevitable though. I already have one on hand but wanted to avoid using it if possible. |
