Bronco front battery tray size?? Can anyone get the x,y,z measurements for the front secondary battery tray with the bronco body on? I'd like to get a 2S battery for that spot before I get home. |
Re: Bronco front battery tray size?? I can measure it when I get home if somebody doesn't beat me to it. |
Re: Bronco front battery tray size?? Yeah thatd be nice. Ive been guessing at the battery size i could fit there. I only have my phone on me and am not aware of an app I can use to get dimensions from a picture that already has some measurements laid out. |
Re: Bronco front battery tray size?? Quote:
https://www.amainhobbies.com/protek-...116-17/p662759 |
Re: Bronco front battery tray size?? Yeah that battery should fit, Natedog. Thats exactly what Ive been looking for. Thanks for the info. |
Re: Bronco front battery tray size?? Nice. But 100C, is that a bit much or will it not affect anything? All my other batteries are 20C so I have no idea. |
Re: Bronco front battery tray size?? The more C, the better, can't hurt anything. :) |
Re: Bronco front battery tray size?? Motor/ESC only pulls the amps it needs. A higher C rating only means the battery can deliver more current/amps on demand, without any damage to the battery. |
Re: Bronco front battery tray size?? Height: 26.5mm from plate to top of inner fenders (nothing on the chassis limits height though) Width: 95mm measured at center of plate (tough to measure with my calipers. Front edge of inner fender has about a 4mm narrower section for a total of about 8mm narrower at the front) Depth: 51.6mm front of plate to servo |
I'm working on my own low profile battery tray. "thumbsup" |
Re: Bronco front battery tray size?? I'm getting at least 2 hours out of the Protek 3S, larger packs don't crawl as well. I always carry spare body clips, screws, CVDs, spur gear and a few other parts. Let's see it! :) |
I bring spare parts as well, but still. It's only a solid model that I have at home. I won't post it until it's installed. |
https://www.amainhobbies.com/protek-...116-19/p846216 |
Re: Bronco front battery tray size?? The 3600 fit and performed great while it worked, however I lost a cell after only a few months. I believe Natedog also had issues with one of more of these. Just a heads up. |
Re: Bronco front battery tray size?? I love my protek 3600 I do want to pick up a 4100. My cheap 2200’s usually last 2 hours in my axial rig not sure on run time in the trx but the protek is easily over 2 hours. Sent from my iPhone using Tapatalk |
I have a keenstone up100AC from Amazon for around $40 that will do LIHV cycles. |
Re: Bronco front battery tray size?? Gotcha, thanks. I was looking at it mainly for the size to mah capacity to fit in the tray of the Bronco. The added voltage would just be a bonus. "thumbsup" |
