Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: You might not have seen one of these before:-)
Old 03-12-2018, 02:11 PM   #21
Inspector86's Avatar
Default Re: You might not have seen one of these before:-)
Just FYI, the rear diff lock cable is about 1" longer than the front so I would think you could install a rear cable up front and it might solve your cable problem.
Inspector86 is offline   Reply With Quote
Old 03-14-2018, 09:28 PM   #22
Bulldog's Avatar
That is true...it would work fine, but then you have to buy it. My mod worked alright, but the abs glue didn't hold. I ended up using epoxy the second time around and once it was glued, drilled a longer pilot hole through the plastic and the epoxy. It should hold now.
Bulldog is offline   Reply With Quote
Old 03-15-2018, 07:27 PM   #23
Bulldog's Avatar
So I had to change gears on the bumper. Time is slipping away. I decided to oick it up later when I can get it perfect. So I went with a big ugly tube one instead. I also fabbed up a windshield visor out of styrene.
Old 03-15-2018, 10:30 PM   #24
Originally Posted by Bulldog View Post
So I finally got my wheels all locked up (pun intended!) and mounted. It’s sitting pretty now. Plenty of clearance for the big meats. I ran into a few problems after the lift though. With 110 shocks, the front diff cable is too short, so I hacked a chunk off and dropped it. I glued it with ABS glue. We’ll see if it holds. Otherwise I’ll fab something else up. I also addressed the bs micro servo problem and put a full size servo in. Fixed!
Next up is figuring out the 4 channel locking situation and the aux wire for the mamba x.
Awesome job so far. That is a killer color scheme and perfect choice on the tire/wheel combo.
I had the same question for the Mamba X Aux wire and the below video and thread answered my question. Hope that helps.
Mamba X Castle Link Help
cmbscx10 is offline   Reply With Quote
Old 03-15-2018, 10:36 PM   #25
Bulldog's Avatar
Thanks for the vid...I forgot to post up...that's exactly what I did. The only other thing I did was get a t-lock setup for the diff lockers. I didn't install it though. I skipped the rear locker and just used channel 4 and set new endpoints for the front locker. I figure all my other trucks have locked rear, and this has over under drive gears, so locked front will give me plenty of pull when it's engaged.
Old 03-16-2018, 08:40 PM   #26
Bulldog's Avatar
Finished bumper two, made a scale cb antenna out of a pen spring, body mount, airplane pushrod and some shrink wrap! Looks the part I think. Got the bumper all glued, sanded and painted and mounted magnets to secure the body instead of the body clips.
Old 03-24-2018, 08:46 PM   #27
Bulldog's Avatar
Killer day wheelin!
Old 03-26-2018, 10:38 PM   #28
Looks like a beast. What are the black wheels you have mounted in the black/red body photo?
HTFU Defender is offline   Reply With Quote
Old 03-27-2018, 10:33 PM   #29
Bulldog's Avatar
stock axial 10.2 kit wheels.
Old 03-28-2018, 10:40 AM   #30
Lookin Tough!!
Summitonslingrs is offline   Reply With Quote
Old 01-23-2019, 07:54 PM   #31
Solid work as usual, just started putting my defender together keeping it subtle and clean.
moedawi is offline   Reply With Quote
Old 01-23-2019, 08:00 PM   #32
Bulldog's Avatar
Thanks Moe. I don't get to build much lately. But I love this truck! I have a couple of updgrades. Maybe I can post up if I get a chance.
Old 01-23-2019, 08:58 PM   #33
Wow, looks great! Love the color.
Tmaxxed is offline   Reply With Quote
Old 01-05-2021, 10:27 PM   #34
Bulldog's Avatar
Just realized I never posted a vid of this. I never get time for scalers these days....
https://www.youtube.com/watch?v=32dgPKcGdJM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
