03-03-2018, 07:36 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: UK
| xl5-hv reversing issue
Hi folks. I’ve got 50km on my rig now. Recently the xl5-hv has started to have a odd issue. I have a BEC wired in so its not working too hard but it’s struggling to go in reverse. Can sometimes take a few attempts before it responds. I have reset the TQi and re-input the esc mode to no avail. Is this just a sign of the esc failing? I notice in neutral the green light is not always on. Sometimes flickering and often off. Any info appreciated. |
03-03-2018, 05:55 PM | #2 | |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: xl5-hv reversing issue
Check out this thread Mode 5 originally back in August. Might play with the sub trim. Also make sure the trigger is fully seated in which ever mode you are running in, 50/50 or the 70/30 if that got bumped it can affect the way the radio interperates its dead band. Quote:
03-04-2018, 05:27 AM | #3 |
Ah many thanks. I have reset the TQI to no affect. I’ll check the tuning. Many thanks.
04-01-2020, 07:26 AM | #4 | |
Newbie Join Date: Jan 2010 Location: Italy
| Re: xl5-hv reversing issue Quote:
I had the same problem, and all over the forums nobody could understand the problem. If you are running the right mode like for example CRAWL or TRAIL MODE your issue can be solved following the step in this video by traxxas you can find on traxxas videos support page or just go here and follow the steps https://traxxas.com/support/video#/?...Id=0&videoId=8 or here https://www.youtube.com/watch?v=KM0IRJUT9Ew Last edited by TIX74; 04-01-2020 at 08:06 AM. | |
04-01-2020, 12:11 PM | #5 |
Pebble Pounder Join Date: Jul 2013 Location: Germany
My non-HV-XL5 in the Stampede had a similar Problem after water corrosion made a bit resistance between the three coolers. One is more or less battery plus, one a motor pole, and a bit resistance between those two gives athe measuring electronics a signal making it think the motor is still turning so it won't brake and reverse. Try to clean the muck and then isolate the coolers with silicone spray or a thin layer coating spray. |
xl5-hv reversing issue - Similar Threads | ||||
XL5 esc issue | FossilJunkie | Formula Offroad | 7 | 06-11-2012 04:10 PM |
Spektrum DX3.0 Reversing Issue | keithgemmill | Axial AX-10 Scorpion | 2 | 08-13-2010 09:36 PM |
reversing? | rmdesignworks | WRCCA Rules | 16 | 12-25-2009 08:17 AM |
xl5 issue | jetboat | Non Crawler RC's | 6 | 06-30-2008 05:19 PM |
Reversing HELP! | Nova | Electronics | 3 | 08-17-2005 12:00 AM |
