Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: TRX-4 Transmission Gear Tooth counts?
Old 03-22-2018, 07:41 PM   #1
Default TRX-4 Transmission Gear Tooth counts?
Hey Guys,
I have done some searching and can't find the answer to this one.
Can someone please give me the tooth counts for the transmission gears?
input gear and hi and low output gears.
i am trying to plug it into my spreadsheet program so I can play around with pinion size and motor kV.
Here are the numbers I do have
Pinion 11T Spur 45T
Transfer case 27-27-27
Axle pinion 11T - Ring 34
Portals input 10 outut 23
Trying to finish this puzzle:
Lance Carbuncle is offline   Reply With Quote
Old 03-23-2018, 09:41 AM   #2
binaryterror's Avatar
Default Re: TRX-4 Transmission Gear Tooth counts?
High is 30T driving 24T = 0.8:1
Low is 18T driving 36T = 2:1
binaryterror is offline   Reply With Quote
Old 03-23-2018, 07:02 PM   #3
Hey man,
Thanks so much for the reply!
Here is my calculator with the TRX 4 Gear Data input.
Let me know if it looks correct.
I have been working hard on making this spreadsheet tool that calculates all gear ratio combinations by changing gears, voltage, kV, etc. I have it for download in the general crawler forum.....
Feel free to download it, play around, and give me some feedback!
Advanced Brushless Motor Vehicle Speed Calculator
TRX-4 Transmission Gear Tooth counts? - Similar Threads
Gearing question same ratio different tooth counts? GTSLOW General Crawlers 7 02-28-2016 10:20 AM
20 Tooth Drive Gear... Land Crab Axial Wraith 5 08-16-2012 03:10 PM
96 tooth Spur gear for Axial Transmission? Nova's Ark Axial AX-10 Scorpion 9 08-05-2008 11:13 AM
