Using the 2075x for two speed shifting. Rather than sell the 2075x use it as your two speed servo. All you need is a couple of Axial type servo mount tabs. I cut one mount off the esc and used 3m tape along with the other screw point. You can the use the 2065 as a spare should one pop. At some point I’ll make a bracket and swap out all the 2065 servos. https://plus.google.com/+PaulWhisker1/posts/5EeQP1eg65m Hopefully someone will find this useful. :-) |
Re: Using the 2075x for two speed shifting. Quote:
Sent from my SM-G955U using Tapatalk |
Re: Using the 2075x for two speed shifting. It's a Savox 1256TG. Powered by a Castle BEC. |
Could see rigging up something similar on the other side for deiff servos. |
Re: Using the 2075x for two speed shifting. Any servo mounts will do. I just had some axial ones lying around. :-) |
Re: Using the 2075x for two speed shifting. Did you make any end point adjustments? |
Re: Using the 2075x for two speed shifting. No. I just kept adjusting the servo saver until I found the sweet spot. |
