07-08-2018, 06:05 PM | #121 | |
Rock Crawler Join Date: Jul 2015 Location: Butler, Pa
| Re: TRX-4 Jeep Cherokee Quote:
07-08-2018, 06:09 PM | #122 |
Here is the picture Sent from my iPhone using Tapatalk |
07-09-2018, 11:01 AM | #123 |
Awesome. I appreciate the rely and pic. Helps a ton. I'm going to get rid of the front rock lights area on fender wells to give some breathing/smashing room.
07-09-2018, 01:12 PM | #124 | |
The other thing that is different is I flipped the front mount upside down so the bumper is higher that is probably why I'm not hitting the rock light buckets also | |
09-07-2018, 08:27 PM | #125 |
I haven't forgotten about the XJ it's locked up on the down hill Sent from my iPhone using Tapatalk |
09-11-2018, 09:10 PM | #126 |
| Re: TRX-4 Jeep Cherokee |
09-11-2018, 09:17 PM | #127 |
09-12-2018, 06:36 PM | #128 |
09-12-2018, 07:03 PM | #129 |
09-12-2018, 07:07 PM | #130 |
Here you go from the underside. As you can they are long and should have plenty of room. Dumb question but are sure you don't have a rear bumper mount up front? Sent from my iPhone using Tapatalk |
09-12-2018, 10:25 PM | #131 |
I'm actually using the LURC Zero Vertical offset 3D printed bumper mounts front and rear but they have the same horizontal offset as the stock mount. https://www.shapeways.com/product/JE...ionId=64635416 My bumper seems to be located very close to yours relative to the body but it appears you mounted your body slightly forward of the stock SCX10ii mount location. My body came off of an Axial SCX10ii chassis and the mount holes were already in place when I purchased it. Looking closer at my bumper it has the same mount bars as yours. However, if I install the bumper mount on the frame in the same orientation front to rear as yours my bumper is about 1/4" further forward relative to the body. I had to reverse the front bumper mount in the frame in order to move the bumper further aft. I suspect the difference is in the position of the body on the chassis. I have ordered some of the LURC ZeroH ZeroV bumper mounts which should allow for proper adjustment. BTW, this chassis was originally a Bronco TRX4 and the body was from an SCX10ii. The front chassis and body mounts were not changed only lowered to accept the Cherokee body. The body had two sets of rear mount holes and the rear Bronco mounts fit the extra pair of holes in the Cherokee body again just lowered. The front wheels centered in the front wheel wells perfect but the rear axle was about 3/16" too far forward for the rear wheel wells. I installed Jato rod ends on the aft end of each of the four rear links and which moved the rear axle back to the exact center of the rear wheel wells and gave the chassis a 12.5" wheel base. Last edited by Inspector86; 04-17-2019 at 05:25 PM. |
09-19-2018, 07:15 PM | #132 | |
Upon a second look I did actually mount my body slightly off of the Axial dimples. I also have metal washers on the body posts and brass tabs on the body which raised it up. I think that's how I was able to use the stock front bumper mount. The wheels are centered the best I could get them which is ok with me. Sent from my iPhone using Tapatalk | |
09-19-2018, 07:17 PM | #133 |
Front dimples Sent from my iPhone using Tapatalk |
09-19-2018, 07:23 PM | #134 |
Trying out the SSD +6 brake rotors on the SSD D hole wheels I didn't think that the rotor would move the wheel out that far but I am liking the look of it Without +6 rotor With +6 rotor Sent from my iPhone using Tapatalk |
09-24-2018, 10:26 AM | #135 |
Got some detail work done Detailed No detail Sent from my iPhone using Tapatalk |
09-24-2018, 10:43 AM | #136 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
That tint looks great! What did you use?
09-24-2018, 01:13 PM | #137 |
09-24-2018, 03:24 PM | #138 |
Did you paint the door gaps or is that striping tape? I would love to see more information on how you did that. It really makes the body pop!
09-24-2018, 03:55 PM | #139 | |
It's just using the Sharpie black fine marker. Get the tip started in the groove and with a steady shakin hand just follow it around. It takes a couple tries to get to straight but it wipes off with rubbing alcohol. | |
10-14-2018, 06:36 PM | #140 |
Took the XJ out for its first real trails Sent from my iPhone using Tapatalk |
TRX-4 Jeep Cherokee - Similar Threads | ||||
Jeep JK TRX-4 Build | Crawler505 | Traxxas TRX-4 | 46 | 05-12-2019 07:16 PM |
Old School Jeep Theme Song Commercial Remake - C1 Cherokee - 4wding is fun in a Jeep | Sp3cia1-K | Scale Videos! | 5 | 11-10-2014 12:31 AM |
Jeep Rubicon vs. Jeep Cherokee | DAGUL | Scale Videos! | 1 | 03-22-2012 05:26 AM |
