04-02-2018, 11:13 AM | #1 |
Rock Stacker Join Date: Mar 2016 Location: Santa Rosa
| Hitec servo arm compatibity
Just picked up a TRX4 kit last week and going to put a Hitec 7950 in it. Doing some forum research it looks like there are potential clearance issues depending on the servo arm used hence a few manufacturers making TRX4 specific arms. Looks like nobody is making specific ones for Hitec's 24t splines. Anyone have any suggestions for Hitec compatible arms that keep the stock geometry intact? Looks like the hole in the stock arm is at 22mm. Unfortunately nobody ever lists the hole distances in various servo arms
04-02-2018, 11:41 AM | #2 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: Hitec servo arm compatibity
They are a few on here that run Hitec servos and will more than likely chime in in soon. You might reach out to Samix RC, they just came out with specific TRX4 horns but right now they are in the 23 and 25 splines. I’d imagine they are will drop a 24 also. Give them a hollar Samix RC/TRX4 |
04-02-2018, 02:44 PM | #3 |
Thanks for the suggestion. I'll look into the Hudy one. Has anyone run the Vanquish horns. My LHS has those in stock. Something I can pick up locally is preferred. I'd hate to have to pay shipping for just a servo arm unless I need to lol |
04-02-2018, 03:45 PM | #4 |
Rock Stacker Join Date: Mar 2009 Location: Holland
| Re: Hitec servo arm compatibity |
04-02-2018, 04:11 PM | #5 |
Quarry Creeper Join Date: Aug 2007 Location: Montrose
Not sure if this will be an issue with this particular servo but I fried mine and had a Hitec 645MG laying around. I went to mount it in my TRX and the mount was different. The "4 ears" did not line up at all. I mounted two screws perfectly and the other two fit in the slots by the hole but not in the holes. Not even close. I hope that made sense... |
04-03-2018, 02:27 AM | #6 | |
Quarry Creeper Join Date: Jan 2011 Location: murrieta
| Re: Hitec servo arm compatibity Quote:
04-03-2018, 05:53 AM | #7 | |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I have these on order for mine currently based on Natedog's suggestion and reviewing the geometry. | |
04-03-2018, 06:50 AM | #8 |
Tekno makes a very good low profile clamping servo arm. I have one on my Ascender which needs maximum clearance between the panhard and servo arm. It seems the 24T version is getting more difficult to find these days unfortunately. Since Hitec has switched their newer servos over to 25T splines, there must not be much demand from racers for a horn to fit older servos. |
04-03-2018, 08:22 AM | #9 |
Newbie Join Date: Jan 2018 Location: Lincoln
My friend is running a Hitec servo with a Vanquish horn. He only gets half to 3/4 suspension compression as the pan hard bar hits the horn...
04-03-2018, 08:49 AM | #10 |
| Re: Hitec servo arm compatibity My buddy has a vanquish horn on his and checked his last night. He said he was loosing about an 1/8" in travel at full compression but no travel loss from when compressing side to side.
04-03-2018, 10:22 AM | #11 |
Quarry Creeper Join Date: Feb 2016 Location: Pembroke ON Canada
VP makes one I'm pretty sure Sent from my FRD-L14 using Tapatalk |
04-03-2018, 12:24 PM | #12 | |
RCC Addict Join Date: Feb 2012 Location: UK
04-03-2018, 01:10 PM | #13 |
| Re: Hitec servo arm compatibity Servo horn upright is drop. I guess installed it would need lift.
04-04-2018, 08:13 AM | #14 |
Once these Hudy come in I bet I'll be done finally. The stock truck I am using a 23T so not much option. I just used a standard (Robotronic, Vanquish, Pitbull, Integy, etc) and then spaced the servo up. In my case with a Robotronic it was exactly 2.5mm that was the issue. My other Class 2 build has just TRX-4 Axles but I'm using a TRX-4 specific servo due to the electronics fitment. It's the SSD and works well but I'm also modifying the CVD's and portal boxes to increase steering, so I will likely need more throw than the SSD offers. |
04-04-2018, 01:07 PM | #15 |
04-04-2018, 01:29 PM | #16 | |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
Hitec servo arm compatibity - Similar Threads | ||||
I need a better arm for my Hitec HS-645 MG servo | acrosteve | Electronics | 6 | 07-06-2009 09:31 AM |
