04-11-2018, 10:41 AM | #1 |
Rock Stacker Join Date: Mar 2016 Location: Santa Rosa
| TQI endpoints question
So i'm trying to set the endpoints on my stock TQI tx after installing a new servo. Figured out how to navigate the menu tree to get to the endpoint adjustment but it seems to be not working the way it should. When I turn the wheel where I want the first endpoint and press set the servo all of the sudden will jump way past that desired endpoint. If I then go to the other side to try and set that point it is actually getting reduced throw. I tried this a number of times after resetting to the default endpoints with the same results. Short term I ended up resetting to the defaults and adjusting the steering rate so that there was no binding but it's bugging the hell out of me what i'm doing wrong to set the correct endpoints. Anyone else experienced this? Maybe i'm understanding the instructions wrong.
04-11-2018, 10:44 AM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: TQI endpoints question
Had the same Solved it by try and Error... Send by my Pixel 2 XL with Tapatalk Last edited by magic_yeti; 04-11-2018 at 01:48 PM. |
04-11-2018, 02:22 PM | #3 |
Pebble Pounder Join Date: Jan 2017 Location: Brookfield
Maybe a visual will help? I used this video to help me set the end points. I hate reading through the instructions. Seems like a map. https://youtu.be/eyZwhVIltGs Sent from my SM-N950U using Tapatalk |
09-08-2018, 02:36 AM | #4 | |
Newbie Join Date: Aug 2018 Location: Sorel, Quebec, Canada
| Re: TQI endpoints question Quote:
Have you been able to resolve that problem ? I have te same trouble since I fried the stock one and replaced it with another one... Driving kinda sucks... I have full 45 degree steering when I go right... and like 20 degree steering when I go left... Guess I'll start everything over from scratch and reset the servo horn to see if I can manage something... | |
09-08-2018, 09:51 AM | #5 | |
Yeah that sounds like the servo horn is not installed in the center of the servo travel. Last edited by Inspector86; 09-13-2018 at 06:56 PM. | |
09-08-2018, 02:34 PM | #6 | |
Guess I'll have to trick it by moving the servo arm a tooth or two by the right and maybe reseting the sub-trim... Seems good ? | |
09-08-2018, 02:52 PM | #7 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Not sure if this might help anyone or not but shaving some material off of the inside of the servo ears can do the trick. Then you can fine tune the placement of the servo ( as long as you're not moving the servo too far and drastically throwing off dead-center). I've done this on both my TRX4's and have experienced absolutely no visible sign nor hindrance of performance regarding wheels turning in one direction more/ less than in the opposite direction.
09-08-2018, 05:29 PM | #8 | |
Yeah, I've done it a few times on my basher rigs, nice tip But actually, I'm using an Axial metal horn on this one. Won't help it this time! | |
09-08-2018, 09:11 PM | #9 |
I'm talking bout the servo ears themselves ( where the servo attaches to the front mounting plate)... essentially removing enough material to turn the four mounting holes into slots so that you can slide the servo left or right rather than being limited by the stock location. I'm actually using a HH shv500 v2 fwiw but same deal... I just shaved enough material on either side of each mounting hole to allow the servo to be positioned to the left or right of the stock location. As long as the mounting screws are tightened down securely, you shouldn't need to worry about the servo sliding around when the truck is in use. You can see in the pic that the servo isn't perfectly centered which is exactly what I wanted. Finally I'm able to not have to keep messing with the epa feature on the tqi tx. |
09-08-2018, 10:01 PM | #10 |
| Re: TQI endpoints question Quote: I hadn't tought about that... I'll try that trick if I can't get the steering I want by moving the servo arm from a tooth and resetting the sub-trim... Thanks a lot for the sharing ! |
09-08-2018, 10:57 PM | #11 |
No prob... and I don't explain things very well.. that was my bad. I too tried setting the epa on the stock transmitter and had the same issues as others have had... where I'd get it set in one direction ( always passenger side) but then when trying to set it for the left/ driver side, it would jump and set itself in the wrong position or not at all. Anyway... I thought when I did this mod that I might also have to adjust the length of the steering linkage to compensate for the servo being in a slightly different location but by the time I centered the servo horn, centered the steering trim, and finalized exactly how far to move the servo... there was no need to make any further adjustments. Make sure to take notice of the full throw/ travel of the servo horn after doing anything like this so that you're able to see that the travel is the same left/ right, and that the horn isn't making contact with the frame rail or the servo mounting plate. |
09-09-2018, 02:32 AM | #12 | |
Should have time to take a look on my TRX-4 monday or tuesday night. Will give some feedback of how it went! | |
09-09-2018, 05:10 AM | #13 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
sounds to me like the sub trim is not set properly, i'd remove your horns and center the sub trim via the programming menu and the multifunction knob, once set to the center (12 o'clock) position on the knob then reinstall the horn, now go in and set your end points. if your sub trim is out of wack then you will not get the full range of rotation from the servo l & r. thats why you cannot get the end points to set correctly, the servo has no idea where its true center is. hope this makes sense and helps. i had to do this when i got the defender and before the bluetooth module came arrived. if you don't have it nearby here is a link to the manual page 34-35. |
09-09-2018, 06:13 PM | #14 |
All makes sense and is helping I was pretty sure I setted teh sub-trim and servo horn right but... mehhh I'll make sure to reset everything from scratch and reinstall the servo horn and all... As I said, I'll take a look on it tomorrow night or tuesday, as I'll be in "weekend" (currently at work now... yeah I know, I have a weird schedule) |
09-11-2018, 08:14 PM | #15 |
Problem solved after resetting and some tweaking !!! The TRX-4 is finally able to get 45 degrees stirring angle on both side Thanks to all for their inputs and support |
12-29-2018, 08:26 PM | #16 | |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
Sent from my SM-N950W using Tapatalk | |
12-30-2018, 12:31 AM | #17 |
Pebble Pounder Join Date: Jul 2013 Location: Germany
Did you upgrade the Firmware on the Tx and Rx (all of them!) with the Link module? The settings of "BT mode" and "non BT mode" are different because the Link overwrites them somehow, i noticed that too. But the problem with the EPA (and some other firmware quirks) were solved when i upgraded my Tx from the stock 1.x to the latest this summer. |
12-30-2018, 06:48 AM | #18 | |
12-30-2018, 12:57 PM | #19 |
Newbie Join Date: Sep 2018 Location: Italy
I have a similar problem because I reversed the serve direction since I mounted it on the bumper support, it flips the action but NOT the endpoint settings, so when you think you're setting the right one you're setting the left one instead and viceversa, VERY frustrating getting those correct without the link module and lots of trial and error.......
12-30-2018, 03:28 PM | #20 | |
TQI endpoints question - Similar Threads | ||||
Traxxas TQ TQi Compatibility Question | thehighroad | Electronics | 0 | 10-17-2014 02:14 PM |
TQi question | LAIDBACKLINNIE | Electronics | 2 | 08-25-2012 11:29 PM |
PROPER way to set dig endpoints? | Deezul | Newbie General | 5 | 11-20-2009 09:56 AM |
Servo Endpoints | nightcrawler86 | Electronics | 0 | 06-14-2009 05:13 PM |
servo endpoints | Dirby | Newbie General | 2 | 12-30-2007 12:22 PM |
