04-21-2018, 01:40 PM | #1 |
Newbie Join Date: Sep 2017 Location: East of the Bay
| Salzar's Bronco Debuild
Wanted to try something non-axial and ebay had a great deal so I grabbed a TRX-4 Bronco in March 2018. First unboxing test fitting some batteries. Changed the Tires to Pitbull Ironsides and added a HH Revolver and SideWinder4. After A day of running it was clear that some things were holding back the car. Front and Rear bumpers were a little to large, and were getting hung up often. Next I added diff locks and under/overdrive gears. Also moved the battery to the front of the car. Added the Single Speed kit (removed last micro servo), MIP Wide kit, and a Brass front Servo Mount. This required a new electronics tray. Also added a rear battery mount to fit larger packs. Added soft springs to rear shocks. New Hyrax tires. Also removed 1.5" of the rear frame to reduce hangups. Added mounts for a beater truck body that is a bit narrower. Climbs a bit better but still needs some tuning. Last edited by salzar; 04-21-2018 at 02:01 PM. Reason: Image size |
04-22-2018, 01:47 AM | #2 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: Salzar's Bronco Debuild
Looks good! You gonna add any bumpers with that bod? How much was the rig on eBay if you don't mind me asking? Was it new or used?
04-22-2018, 11:42 AM | #3 | |
| Re: Salzar's Bronco Debuild Quote:
New bronco from Ebay was $359 after using a 20% off coupon. | |
