04-22-2018, 03:57 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| TRX weightloss tip
My TRX need to loose some weight to be a competive scale crawler. What's the best tip to loose some weight? I've changed the body on mine to a proline commanche body, got rid of the shift servos for the axles and made a custom battery mount. I know the links are quite heavy, but what else? |
04-22-2018, 06:37 PM | #2 |
| Re: TRX weightloss tip
There's a lot of plastic that can be taken off like the fender wells. Remove remote locking diffs and servos and install from lockers.
04-22-2018, 07:02 PM | #3 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Maybe shave a few grams by replacing stainless/ steel screws/ nuts with aluminum... low stress areas like plastic, lexan, rx box, etc.
04-23-2018, 02:41 AM | #4 |
This is my current setup. No inner fenders and no shift servos. Lighter body. Lighter and lower batterytray. Lockers and overdrive. Added weigt is brass portal covers front and rear. Sent fra min FRD-L09 via Tapatalk |
04-23-2018, 06:42 AM | #5 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
My rig is 8.2 pounds with no brass and I run a hard body. It’s SORRCA C1 legal and I took first place in both C1 and C2 (still on 4.19 tires) with it yesterday. Weight can be a good thing.
04-23-2018, 06:49 AM | #6 |
Newbie Join Date: Apr 2018 Location: Cold Spring
| Re: TRX weightloss tip |
04-23-2018, 07:19 AM | #7 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: TRX weightloss tip Quote:
Ernie Last edited by CODYBOY; 04-23-2018 at 07:22 AM. | |
04-23-2018, 08:04 AM | #8 |
04-23-2018, 09:21 AM | #9 | |
Think my plan must be to get some titanium links, lighter wheels, lighter chassis (come on Brazin ), convert to single speed and brush less. | |
04-23-2018, 10:17 AM | #10 |
04-23-2018, 10:30 AM | #11 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
There's already brass everything for the TRX on eBay and AliExpress. No wait, not sure if I've seen brass tires. Male that almost everything.
04-23-2018, 12:41 PM | #12 |
RCC Addict Join Date: Feb 2012 Location: UK
Chuck the receiver in a balloon and loose the box if you after loosing every gram. Get rid of the side rails?
04-24-2018, 07:30 AM | #13 |
04-24-2018, 12:19 PM | #14 |
Anyone know the wb of the Samix titanium links? https://www.amainhobbies.com/samix-t...025hls/p702639 I'm looking for 313wb titanium links. |
04-24-2018, 03:46 PM | #15 |
I took a drill bit to the body mounts/posts and shock mount braces to shave a tiny bit of weight, drilling through where it was strong enough to take it and dimpling other areas it wasnt. I cut off the bottom of the body post that hung below the post mounts as I never plan on lifting the body any more. It was a minuet amount of weight Last edited by HumboldtEF; 04-24-2018 at 03:51 PM. |
TRX weightloss tip - Similar Threads | ||||
need a tip | sc10 man | Non Crawler RC's | 2 | 05-08-2012 04:26 AM |
Wraith tip | JUGGARNAUT | Axial Wraith | 2 | 10-29-2011 05:45 PM |
new to berg any tip | gram lanier | Newbie General | 10 | 02-16-2010 12:34 PM |
Rocklights Tip... | HEAVY METAL | Electronics | 3 | 01-12-2008 09:34 PM |
Do You Tip At Sonic? | Robb | Chit Chat | 18 | 08-08-2006 10:07 AM |
