Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: BEC for my trx4
Old 05-06-2018, 12:50 PM   #1
Default BEC for my trx4
I’m searching for a BEC for my trx4. I just ordered a 20KG digital servo(Baja servo). Just to be on safe side, I want to install a BEC. I just do my shopping from amazon.
Darrell is offline   Reply With Quote
Old 05-06-2018, 04:10 PM   #2
cartronicshn's Avatar
Default Re: BEC for my trx4
i have always relied on castle creations for becs
cartronicshn is offline   Reply With Quote
Old 05-06-2018, 04:52 PM   #3
have several of the castle 10 amp bec's just seal the ends with some silicone and you'll be good to go
Castle 10 amp BEC
ScoJac is offline   Reply With Quote
Old 05-06-2018, 08:42 PM   #4
O ok thanks guys.
Old 05-06-2018, 08:44 PM   #5
I still have the stocked esc on my trx4, so do I have to upgrade that also?
Old 05-07-2018, 07:11 AM   #6
No. Just add the BEC and the stock esc will do fine.
o0wiz0o is offline   Reply With Quote
Old 05-07-2018, 07:39 AM   #7
Moderator
JatoTheRipper's Avatar
Instead of wasting money on a BEC just buy the HobbyWing WP 1080 ESC. It's $40 and much better than the stock. The internal BEC is also much stronger and adjustable.
Old 05-07-2018, 07:54 AM   #8
I have been tempted to try one of those esc, they have great reviews, so the internal bec can handle all of the servos without the need of an external bec? interesting, if you say it works great with all the servos then i will definetly try one of these.
Old 05-07-2018, 07:57 AM   #9
Moderator
Supposedly the micro servos for shifting and controlling the remote locking diffs can't handle anything over 6.0V. I set my 1080 to 6.0V and it easily powers all of the servos. And even setting the ESC at 6.0V really wakes up the stock servo. My stock servo eventually stripped gears so I upgraded to the Savox and the 1080 ESC has no issues powering that with the 6.0V BEC setting.
Old 05-07-2018, 08:01 AM   #10
Ok then, i will pull the trigger on one of this esc
Old 05-07-2018, 08:04 AM   #11
Moderator
I think you'll love it! If you find yourself wanting more power for the servo, which I doubt, you can add an external BEC so just the steering servo gets more power and the micro servos are run by the ESC's BEC.
Old 05-07-2018, 08:18 AM   #12
I agree! Exactly what I have in my rig. Good advice.
Old 05-07-2018, 10:26 AM   #13
+1 for the hobbywing 1080. Not only does it power everything I need it to, it can be set to a nearly inaudible 16khz pwm frequently. No more whine!
armoredpig is offline   Reply With Quote
BEC for my trx4 - Similar Threads
With the mamba having 8amp bec is a separate bec still needed drkuhar Electronics 5 08-18-2017 10:16 PM
BEC | Castle Creations CC Bec 10A 6S Switching Regulator le varan Axial Yeti 8 06-02-2015 12:08 PM
BRXL+Castle Link+Bec=? How do i set BEC? crazyorigin Electronics 17 11-21-2011 03:11 PM
using external BEC & esc's internal BEC.... slowlearner Newbie General 2 02-14-2010 01:35 AM
