05-09-2018, 09:56 PM | #1 |
Newbie Join Date: Jun 2010 Location: hk
| pmis's trx4 build
hello everyone. i'm new here. just bought a trx4 kit. still in progress of building. let's start the packing is convenient. you poured everything out in a bag for a part and left nothing after the completion of that part i turned the bearing by hand and found them quite viscous the inside of the gearbox the shift mechanism installed and greased the outputs (to the front and rear axles) the slipper. i didn't follow the instruction in manual as i thought it would make the slipper too tight now for the shift servo. traxxas labelled each servo gear box part completed diffs, exploded view diffs gears diffs completed rear axle as you know the diffs can toggle lock/unlock mode. this is the locked mode this is the unlocked mode the portal part, exploded view portal part finished rear axle completed now for the front axle. similar to the rear one the (pseudo) cv joint, exploded view with one of them built, for comparison front axle finished now these parts completed the main frames of the chassis building the chassis the frames, inner fenders and cross members assembled to be continued Last edited by pourMoneyIntoSea; 12-06-2018 at 08:25 PM. |
05-10-2018, 01:20 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: pmis's trx4 build
Fantastic post! As someone who bought the RTR the quality build pics are appreciated. I’m sure mine will need servicing in the not too distant future and these give great insight. :-)
05-10-2018, 08:53 PM | #3 |
let's continue. time for electronics. motor and gearbox first it is necessary for the receiver to stay horizontal otherwise the gyro inside would not function properly the diffs locking servos all electronics installed. spaghetti near receiver would be hidden later traxxas did a great job in designing the radio box which effectively organize the wires it's neat and tidy now you can flip the battery tray cover to adape different thicknesses i found it impossible to insert the battery tray into its position unless i remove the LR and RR wire mounts first. the manual didn't mention that electronics part finished now the time for shocks the packing of electronics is a good place for the shocks to wait for bubbles releasing shocks finished shocks and linkages on front axle front axle installed shocks and linkages on rear axle rear axle installed it's disappointing that propeller shafts are made of plastic one of them assembled, for comparison it is necessary to align the pins otherwise the universal joints would introduce fluctuation no need to use thread lock during the whole building process. traxxas added thread-locking material on some of the screws chassis basically finished traxxas lipo fits the tray certainly. i like the traxxas plug which integrates with its parallel charging wire wheels and rims are ready building process halts here as the body, proline 1985 hilux which was ordered in ebay, is not yet arrived. to be continue Last edited by pourMoneyIntoSea; 12-06-2018 at 08:32 PM. |
05-10-2018, 08:54 PM | #4 |
| Re: pmis's trx4 build |
05-11-2018, 04:48 AM | #5 |
Pebble Pounder Join Date: Feb 2014 Location: Canada
I remember when mine looked like that....new lol
05-11-2018, 12:59 PM | #6 |
I can't see the pics. Are they social media photos?
05-12-2018, 07:12 AM | #7 |
pmis's trx4 build - Similar Threads | ||||
RPM's TRX4 JK Wrangler Build | rpm | Traxxas TRX-4 | 37 | 03-24-2022 02:26 AM |
bilinvic's TRX4 Bronco Build | bilinvic | Traxxas TRX-4 | 107 | 02-28-2020 05:32 PM |
RPM's Traxxas TRX4 JK Wrangler Build | rpm | 1.9 Scale Rigs | 16 | 06-19-2019 06:10 PM |
Trx4 blazer build | trex4Owner | Traxxas TRX-4 | 10 | 11-20-2018 09:42 AM |
TRX4 #3 (like I need another one) | Inspector86 | Traxxas TRX-4 | 7 | 04-05-2018 05:08 PM |
