05-12-2018, 11:58 PM | #1 |
Quarry Creeper Join Date: Aug 2017 Location: KY
| GRC motor mount?
Anyone running one of these motor mounts? If so, can you provide some feedback? https://www.asiatees.com/display?Tra...RX-4&id=150097 |
05-13-2018, 04:18 AM | #2 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: GRC motor mount?
looks interesting, i'm curious as well. Here is a link to their blog showing it installed, very cool https://www.asiatees.com/article?GRC...-Cover&id=3169 |
05-13-2018, 10:32 AM | #3 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
I've also been looking at these and waiting for a body to be in stock before finally purchasing it. I think that it will make things easier for setting the pinion/spur gear engagement as the normal motor mounts flop around a lot when the cover is removed. Price looks good as well.
05-13-2018, 10:47 AM | #4 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: GRC motor mount? Quote:
Ernie | |
05-13-2018, 06:32 PM | #5 |
Sounds like a nice trip man! Anxious to hear what you think of the mount when you get some time with it.
05-14-2018, 07:08 AM | #6 |
RCC Addict Join Date: Feb 2017 Location: Surprise
Looks like a beefy motor mount. That's cool.
05-14-2018, 11:14 PM | #7 |
Rock Stacker Join Date: Jul 2010 Location: State of Jefferson
Installed one tonight. It is well built but noticed a couple things. 1. The area where the motor bolts to is thicker than stock. I had to move the pinion gear out some so the grub screw would clear the spur gear. 2. In order to remove the motor mount cover, I had to remove the forward battery tray screws and lift the tray up some as the swivel mount for the battery holder blocks it. I may shave some plastic off and see if that makes it easier to remove the cover. Overall, it is a great mount. I may get another one for my Bronco. |
05-15-2018, 01:38 PM | #8 |
Pebble Pounder Join Date: Apr 2011 Location: Madison
engineering/design suggestion regarding the motor plate gear cover assembly... I would make the skidplate/ lower gear cover (TRA823 all one piece, including the vertical plastic motor mount portion of part (TRA8290). Leaving the spur gear cover the only separate piece of the assembly. That alone would tighten things up sufficiently. |
05-17-2018, 07:48 AM | #9 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
Sounds like I might be ordering one of these before too long. Mine just started making way to much noise for my liking.
08-13-2019, 05:53 PM | #10 | |
Newbie Join Date: Feb 2019 Location: Moorpark
08-13-2019, 07:17 PM | #11 |
The extra thickness was actually a plus for me as I am using the Holmes Hobbies Revolver which has a fairly long shaft. Even so I still needed to add a set of Yeah Racing motor spacers as the shaft was still touching the cover. The spacers add 3mm which is enough to fix the problem. I added a little heatsink paste between the spacers and the motor mount runs very close to the same temperature as the motor. The ESC is attached with tie wraps because adhesive velcro doesn't stick very well to the 3D printed battery tray. Tried both Velcro and 3M brands but the results were the same. Sent from my LG-H870DS using Tapatalk |
GRC motor mount? - Similar Threads | ||||
Hot Racing Motor Mount Hits Spur Mount HELP!! | RevoRacer | Axial AX-10 Scorpion | 3 | 05-08-2008 06:06 PM |
