05-13-2018, 03:47 PM | #1 |
Newbie Join Date: May 2018 Location: US
| Trx4 differential issues
Not sure if the problem is inn the diff or the portal axles, but when I turn it I can hear something grabbing Any ideas? Sent from my SM-S327VL using Tapatalk |
05-14-2018, 12:12 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: Trx4 differential issues
If this is when turning at full lock then it’s normal. The steering through goes beyond what the CV is comfortable with.
05-14-2018, 06:05 AM | #3 |
| Re: Trx4 differential issues |
05-14-2018, 06:29 AM | #4 | |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
| Re: Trx4 differential issues Quote:
In all seriousness, the CV has a point where it cannot go beyond it's intended range of motion and will cry for mercy. Nothing you can do about it. This truck already has a great steering radius, especially if it's diff is unlocked. | |
05-14-2018, 06:34 AM | #5 |
Thanks guys. You're correct it does turn very good. Just think that issue will cause wear on those parts. I programmed the turn end points so it doesn't turn all the way. Seems to be better and still turn ok. Sent from my SM-S327VL using Tapatalk |
Trx4 differential issues - Similar Threads | ||||
TRX4 Differential Oil? | malickie | Traxxas TRX-4 | 6 | 10-19-2017 06:13 AM |
Yeti kit front differential issues | OhioSuperSport | Axial Yeti | 14 | 01-26-2015 09:02 AM |
esc issues or elec issues | camogonewild | Newbie General | 5 | 03-11-2014 11:19 AM |
differential | mitchr97 | Axial SCX-10 | 11 | 03-04-2013 02:29 PM |
Rear differential issues? | Kanine38 | Axial AX-10 Scorpion | 18 | 05-18-2010 05:48 PM |
