05-14-2018, 02:44 PM | #1 |
Pebble Pounder Join Date: Apr 2011 Location: Madison
| possible servo choices...
"Coming from AMain Hobbies’ EcoPower brand are two new waterproof servos. The standard voltage WP110T (0.16s/20.1kg-cm) and WP120T (0.09s/28.8kg-cm) are an ideal upgrade for ready-to-run cars, trucks and rock crawlers and they feature metal gears, dual ball bearings and lightweight upper and lower cases with aluminium centre sections. The WP110T is powered by a cored DC motor while the high-voltage compatible WP120T utilises a coreless motor. EcoPower recommends the WP110T servo for all 1/10-scale applications, while the higher power WP120T would be best suited for heavy monster trucks, 1/8-scale vehicles and crawlers." https://www.amainhobbies.com/search?...vos&fs=1&lg=fs |
05-14-2018, 03:25 PM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: possible servo choices... 120T and 110T Gears Metal w/Plastic mid gear no go in my eyes at this price level wouldn't use this on a heavy rig like the trex 20$ more gives you a hh hv500 v2 instead of the 120T and under 20$ you can get a powerhd 20kg WP instead of the 110T |
05-14-2018, 04:32 PM | #3 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
Instant turn off to hear about a plastic gear, that's just asking for trouble. Just take $20 more and head up into the next tier of servos and save yourself the pain.
05-14-2018, 04:52 PM | #4 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
I think they could have offered a full metal gear servo for what an extra $2 ? What a shame, seems like it could have been a good servo otherwise. For the same $69.99 you can pick up a savox 1230mg with ALL metal gears and 499 oz/in of torque @ 6 volts...that’s a a no brainer. |
06-15-2018, 02:45 AM | #5 | |
Newbie Join Date: May 2018 Location: US
| Re: possible servo choices... Quote:
Sent from my SM-G965U using Tapatalk | |
06-15-2018, 03:25 AM | #6 | |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
"Gears - Metal w/ plastic mid gear" | |
06-15-2018, 05:00 AM | #7 |
| Re: possible servo choices... |
06-15-2018, 05:02 AM | #8 |
06-15-2018, 05:20 AM | #9 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
Straight off of Amain's website. |
06-15-2018, 10:36 AM | #10 |
@ mud4x4lover- I can understand the confusion b/c it is listed in some specs as "Metal gears" but Eco-Power is Amain Hobby's house brand and they clearly state that the mid-gear is indeed plastic on both those servos.
06-15-2018, 11:07 AM | #11 |
If you don't believe the words about the plastic gear, here is a pic of the gear set: https://www.amainhobbies.com/ecopowe...p-3099/p755536 Clearly a plastic gear. |
06-15-2018, 04:23 PM | #12 |
Back when they first hyped these servo's being released, I was sorely disappointed in the fact that they had the plastic middle gear. Since then, their blurb has been repeated all over this forum, which is really unfortunate. Situations like these are bad for people somewhat new to crawling, as when a retailer pushes a product for a particular niche of RC the natural inclination is to believe their recommendations. People have been trying to catch all mentions of the particular servos when they popped up on the forum and reply with a post clarifying the product spec with the mention of the gear's construction materials. As evidenced by several posts elsewhere, failing electronics can turn people off to the hobby as a whole - no one likes having to call an end to their day of crawling and then wait on replacement parts... To show all the work members have gone through to help get the word out regarding the plastic gear - look at ALL of these posts in response to the EcoPower being mentioned: What the newest cheap servo hotness? possible servo choices... Ascender'nMN builds WB4 II Ecopower servos? Budget waterproof servo options |
06-15-2018, 04:35 PM | #13 | |
06-15-2018, 05:12 PM | #14 |
No worries - it's VERY easy to get caught out by spec sheets that list partial or completely incorrect information. A great example - "Titanium" servo gears... They are in reality ALWAYS coated aluminum, not an actual gear machined out of titanium material. |
06-18-2018, 01:01 PM | #15 | |
Newbie Join Date: Sep 2017 Location: Austin
11-30-2020, 04:32 PM | #16 | |
Rock Crawler Join Date: Mar 2013 Location: columbus
Sent from my SM-G975U using Tapatalk | |
12-03-2020, 06:17 AM | #17 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
You will need to run a BEC to power (both volts and AMPS) your Servo and a Bypass to power the rest of your TRX so you don't want to run the risk of possibly damaging other electronics. Even if you are running a 6 volt out of your ESC and have a 6 volt servo it is doubtful that you are pushing enough amps out of about ANY ESC to get you servo to really work like it can. I would strongly consider getting a direct power servo so you can have all the power and torque without having to use a BEC or bypass. All the power the servo needs straight from the source. I have couple direct power and a few regular servos and for me my favorite is the direct power 3Bros G13. Last edited by MOguy; 12-03-2020 at 06:25 AM. |
12-03-2020, 07:31 AM | #18 | |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
Imo, spot on with the direct powered servos. The G13 replaced my stock servo. I was happy with its performance. Definitely quieter than the HH SHV500 v3 that’s in there now. | |
possible servo choices... - Similar Threads | ||||
So may servo choices...Which one to choose? | cpu77 | Axial Yeti XL | 14 | 02-19-2017 09:27 AM |
4ws servo choices | drkuhar | HPI Wheely King | 0 | 04-25-2012 08:47 PM |
Servo choices for steering and dig? | stevehof | Axial AX-10 Scorpion | 10 | 11-04-2008 06:00 PM |
new servo choices for my xf | RampageFSJ | Electronics | 4 | 05-04-2006 08:33 AM |
steering servo choices | elvis | Electronics | 4 | 08-24-2005 12:12 AM |
