05-18-2018, 02:15 PM | #1 |
Rock Stacker Join Date: Mar 2018 Location: Denver
| Diff lock question/problem
My front axle housing cracked and I had to replace it. I feel like I reassembled it correctly. Here is the thing though. When the locking cable is pulled it, more often than nor, doesn’t lock instantly. Instead the tires have to be rolled a bit and the lock will then slip into place. On my newer Bronco TRX4 and on the rear axle of this truck the diffs lock immediately and the wheels do not need to be turned to get the lock to engage. Did I do something wrong during my reassembly. Thanks.
05-18-2018, 02:24 PM | #2 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
| Re: Diff lock question/problem
The diff lock mechanism gets gummed up VERY easily, did you put any grease on the arm/slider?
05-18-2018, 02:36 PM | #3 |
Yep, it is all greased up. If the drive shafts are not inserted it locks and unlocks instantly.
05-18-2018, 02:42 PM | #4 |
I found it worked better with the arm and slider dry, but if removing the driveshafts changes it's behavior, you might be having a totally different issue... The first time I rebuilt my axles, I lubed the arm and slider liberally, and it wouldn't engage without a little rolling help. Came on these forums and found others saying to run the arm and slider dry. Took the axles back apart and cleaned the grease off the arm and slider, reassembled and the problem went away... Last edited by JSterrett; 05-18-2018 at 02:45 PM. |
05-18-2018, 03:02 PM | #5 |
Ahhh, gotcha. I may be taking it apart again. Thanks.
Diff lock question/problem - Similar Threads | ||||
Front diff lock problem | HTFU Defender | Traxxas TRX-4 | 4 | 05-06-2018 09:23 AM |
Question: HR heavy duty diff posi lock spool YEX2508 | davesteroo | Axial Yeti XL | 2 | 09-05-2016 05:26 PM |
Slash and diff-lock question | KuJo | Non Crawler RC's | 11 | 04-26-2009 12:53 AM |
Lock Snot, Diff lock | JohnRobHolmes | General Crawlers | 10 | 09-29-2007 05:54 PM |
diff lock question | cornolio | Tamiya Clod Buster | 6 | 08-23-2005 11:34 PM |
