05-25-2018, 01:46 PM | #1 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
| Axle mounted servo?
I have an older axial axle based truck that id like to update to the trx4 drive line. my only problem is the truck cant be setup with a cms. anybody know of an axle mounted servo piece? |
05-25-2018, 02:10 PM | #2 |
Quarry Creeper Join Date: Feb 2016 Location: Pembroke ON Canada
| Re: Axle mounted servo?
Don't know of any. You Might have to scratch build one or get it 3Dprinted Sent from my FRD-L14 using Tapatalk |
05-25-2018, 02:58 PM | #3 |
| Re: Axle mounted servo? |
05-25-2018, 03:50 PM | #4 |
Do you already have the axles, or is this in the planning stage? The reason I ask is because MST's MPA portal axles (used in the MST CFX-W, before the TRX4 was around) uses an axle mounted servo. The aftermarket is almost non-existant, but the cost of entry is reasonable, and durability appears to also be reasonable.
05-25-2018, 04:47 PM | #5 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
Which truck do you have ? If you have the first gen scx10 I believe there is a CMS bracket you can get from the aftermarket. Then all you’ll need is a longer drag link. |
05-28-2018, 10:46 AM | #6 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
I hope to have mine axle servo mount finished in 2/3 weeks
05-29-2018, 10:36 AM | #7 | ||
| Re: Axle mounted servo? Quote:
its a 1 of 1 chassis i had made back in 2008. plus i dont want cms. i prefer triangulated 4-link front and rear and ams performance. looking at the axles this weekend, i have a few designs in my head just gotta draw them out and go from there. im confident i can come up with a good solution. | ||
05-29-2018, 01:22 PM | #8 |
A friend and I were mulling over the idea of using/making a clamp-on mount that would mount the servo on/behind the long side tube, inspired by Dlux's AR60 truss. I'm sure there's many ways to skin this cat if you've got a creative mind, a drill, and a saw!
10-05-2018, 04:17 PM | #9 |
Pebble Pounder Join Date: Jul 2016 Location: Eugene
Anyone figured this out yet?
10-08-2018, 08:28 AM | #10 |
10-14-2018, 11:55 AM | #11 |
There a guy on Instagram that makes the mounts for trx4 @1tenthscale Last edited by eric113; 10-19-2018 at 09:04 PM. |
10-19-2018, 02:00 PM | #12 |
Can your share the instagram of this guy? Thanks Last edited by Taper; 10-19-2018 at 02:09 PM. |
10-19-2018, 02:14 PM | #13 |
10-19-2018, 05:08 PM | #14 |
Pebble Pounder Join Date: Aug 2005 Location: Gilbert
It's actually 1tenthscale, but here's a link to his site. https://1tenth.com/shop?olsPage=prod...4-link-adapter |
Axle mounted servo? - Similar Threads | ||||
Axle mounted servo | SuperDrty | Axial SCX10 II | 14 | 09-01-2017 07:21 PM |
Axle mounted servo? | metalry101 | Axial SCX10 II | 4 | 08-29-2016 09:43 AM |
axle mounted servo | usa1man | General Crawlers | 1 | 11-11-2007 07:44 PM |
Axle flex with axle brace mounted steering servo? | NoOb | Tamiya Clod Buster | 6 | 02-19-2006 11:04 AM |
Axle Mounted Servo | Mike-63 | Tamiya TLT Crawlers | 7 | 03-21-2005 03:31 PM |
