01-31-2018, 03:47 AM | #1 |
RCC Addict Join Date: Oct 2014 Location: UK
| New SSD Portal Delete Kits
Front: Rear: CNC machined aluminum rear lockouts CNC machined aluminum C hubs & knuckles Hardened steel stub axles 8 Degree King Pin Inclanation (KPI) Track width is reduced by 12mm (6mm each side) Reduces the ride height by 13mm Lowers center of gravity (CoG) Improves stability More details here: Front Axle Portal Delete Kit for TRX-4 Rear Axle Portal Delete Kit for TRX-4 Last edited by SSD; 01-31-2018 at 04:19 AM. |
01-31-2018, 05:43 AM | #2 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
| Re: New SSD Portal Delete Kits Last edited by Taper; 01-31-2018 at 05:45 AM. |
01-31-2018, 06:35 AM | #3 |
Very cool!! Always good to have more options...
01-31-2018, 06:50 AM | #4 |
Interesting!
01-31-2018, 06:54 AM | #5 |
Very cool to have the option. Might want to note it is recommended to only use low gear after removing the portals. A motor can get cooked mighty fast with the incredible high 9.8:1 stock ratio in high gear without portals. At least you could hit about 35mph on 3S before it bursts into flames. |
01-31-2018, 07:30 AM | #6 |
Rock Stacker Join Date: Sep 2017 Location: in a RV
I'm confused. Isn't the reason the TRX4 is so popular is for the portal axles and the other unique systems like 2 speed trans and lockable diffs? If I didn't want those on my Traxxas vehicle why not just purchase a SCX10II.
01-31-2018, 07:32 AM | #7 |
Price of each kit?
01-31-2018, 07:35 AM | #8 | |
| Re: New SSD Portal Delete Kits Quote:
Not everybody stays in a square box. Look around this site. You'll see people love to change and modify things. Options are good. | |
01-31-2018, 07:49 AM | #9 |
I haven't checked the Traxxas gearing options but maybe smaller pinion and larger spur can get some of the gearing back.
01-31-2018, 07:50 AM | #10 |
| Re: New SSD Portal Delete Kits Some people dont like or want portals after running the truck with them.
01-31-2018, 07:56 AM | #11 |
| Re: New SSD Portal Delete Kits The truck comes stock with 45/11 gearing. The lowest possible gearing on the pinion and spur is 45/9 since there is no larger spurs available. That is a little better but it would still only be 12:1 overall gearing in high gear. Low gear is a much more reasonable 30:1 with 45/9 gearing on the pinion and spur.
01-31-2018, 07:57 AM | #12 | |
01-31-2018, 08:33 AM | #13 |
| Re: New SSD Portal Delete Kits |
01-31-2018, 08:50 AM | #14 |
01-31-2018, 11:57 AM | #15 |
Rock Stacker Join Date: Jan 2009 Location: Carthage
I don’t own a trx4 yet. Was curious what circumstances would cause you to not want to stick with portals?
01-31-2018, 01:11 PM | #16 |
Newbie Join Date: Sep 2015 Location: Wolf Creek
A standard rotation motor would be needed as the Titan in trx4 is reverse rotation, correct? Also, motor leads reversed?
01-31-2018, 02:03 PM | #17 |
Pebble Pounder Join Date: Sep 2016 Location: Rio Rancho, NM
I’m not a portal fan so I think this is a great option. Well done SSD! Sent from my iPhone using Tapatalk |
01-31-2018, 02:26 PM | #18 |
Rock Crawler Join Date: Mar 2015 Location: Waltham
It seems like the new Bronco body is going to be a big hit, so these portal delete kits will make folks looking for a more scale look pretty happy.
01-31-2018, 03:48 PM | #19 |
01-31-2018, 03:54 PM | #20 |
Where can I buy both kits?
New SSD Portal Delete Kits - Similar Threads | ||||
New SSD Brass Portal Weights | SSD | Traxxas TRX-4 | 21 | 12-26-2020 02:27 PM |
SSD Super Sale! Up to $25 off select SSD RC Upgrade | RPP Hobby | RPP Hobby | 0 | 11-22-2017 08:41 AM |
