Aux power with a hobbywing 1080 Hi gents, as the title says, I am replacing my stock esc with a hobbywing 1080 so that I can run a JX cls-5830HV 30kg servo. I have the factory traxxas lighting kit for my head/tail lights and light bar all running off the factory aux power port. How can I power these moving to the hobbywing esc? |
Re: Aux power with a hobbywing 1080 Quote:
Or use an auxiliary battery just for it. Sent from my Pixel 2 using Tapatalk |
Re: Aux power with a hobbywing 1080 Or if you are using the internal bec at 7.4v just re do your wiring and plug it into the programming port on the esc. |
That would work if your running a Sport but if you have a Kit, Defender, or Bronco I don't think the diff and shift servos can handle the 7.4V Cleanest way is to splice in a JST connector onto the ESC side of the battery connection which is essentially what they did on the stock ESC. If your not comfortable with soldering you could always go with something like this https://www.ebay.com/i/272804672822?chn=ps You'd just need to double check that the JST end is the correct male/female orientation as I can't remember off the top of my head what orientation the JST coming off the stock ESC is. |
Re: Aux power with a hobbywing 1080 I made up an xt60 adapter to go between the esc and battery with a jst cable added https://uploads.tapatalk-cdn.com/201...1d34593f8b.jpg Sent from my SM-G920F using Tapatalk |
