![]() | #1 |
Newbie Join Date: Aug 2018 Location: yucaipa
![]() | #2 |
RCC Addict ![]() Join Date: Aug 2017 Location: Fredericksburg, VA
Those are the mounts for the Traxxas 8028 power supply which is used to power the Traxxas 8030 light kit. The 8028 power supply also is powered by the red JST plug you asked about earlier.
![]() | #3 |
Ok cool... if I'm going to install the mytrickRc light kit do I still need that plug? If not can I wire the plug up to my BEC for my servo?
![]() | #4 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
I wired my BEC to that plug. No problemo.
![]() | #5 |
Actually it depends on which MyTrickRC controller you choose to buy. The DG-1 or the UF-7. I think the DG-1 can use that JST plug or direct to the balance plug of a 2s or 3s battery. The UF-7 is connected to ch2 of the RX (optionally also ch1) and is powered at 6v from the RX. I used the JST plug to power my BEC until I changed ESCs.
![]() | #6 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Not relative to OP's inquiry but I used the jst connector on mine to directly power my HH shv500v2.
![]() | #7 |
Ok cool... Also what are your guys takes on filling your BEC with hot glue to waterproof them?
![]() | #8 |
Quarry Creeper Join Date: Apr 2018 Location: US
It may work for a while, but as it heat cycles it will be less effective. I'd highly suggest some conformal coating or heat shrink with adhesive. 3M 3:1 is what I use.Sent from my Pixel 2 using Tapatalk |
![]() | #9 |
Newbie Join Date: Jul 2008 Location: toronto
kinda related....https://youtu.be/RNqm5O3kN8E |
Stripped Hex Screw - Craftsman Screw Extractor | bigstu | Tools, and Procedures | 8 | 11-05-2011 08:48 AM |
Need help about my posts | AX-10 Crawler | Comments, Suggestions, and Help | 2 | 08-22-2010 05:30 PM |
My posts are going away | Greatscott | Comments, Suggestions, and Help | 27 | 04-21-2009 03:19 PM |
Side posts vs top posts??? | Mr_Freeze | Paint and Body | 11 | 05-24-2008 02:46 PM |
