Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Trx Bronco ESC problem
Old 09-12-2018, 08:02 PM   #1
Question Trx Bronco ESC problem
Ok I recently got a BEC and upgraded servo. When I got finished installing it the ESC was blinking green after I turned it on. The wheels turned but it did not move. I took it to the hobby store. Where I found out it wasn't finding neutral in the radio. They told me to call traxxas and get a new radio. I called traxxas and they said it was the ESC. That I would have to remove it and send it in. Slight problem with this idea I have tied in the BEC to the ESC. Now I have no idea who to believe. I would like to believe the hobby shop as that way doesn't cost me anything. However my problem being that if the hobby shop is correct how do I get traxxas to see this without sending them my ESC because it's been altered and will null the warranty. If it is my ESC I will buy a new one but I didn't want to take on the financial responsibility to buy a new remote as those can be quite spendy.
Snowflake is offline   Reply With Quote
Old 09-12-2018, 08:38 PM   #2
Default Re: Trx Bronco ESC problem
I think your screwed if it is the esc, Traxxas will no way warrenty it. So saying that get a hobbywing 1080 cause its way better anyways. Then your upgraded there for cheap, then you will find out if the radio is working or not then.
83trekker83 is offline   Reply With Quote
Old 09-12-2018, 08:39 PM   #3
If you plugged the BEC into the JST connector on the stock ESC that is simply a tap off the battery input and is actual battery voltage. Are you sure you are picking up the steering signal from channel 1 and power from the BEC? I would undo what you did and put it all back stock then see if it works properly. If so you have something wired incorrectly. To correctly wire your BEC I recommed using one of these by-pass harnesses from Holmes Hobbies.
https://holmeshobbies.com/electronic...s-adapter.html
If it turns out that you do in fact have a bad ESC, don't waste your time with a stock replacement. Get yourself a HW1080 ESC.
Inspector86 is offline   Reply With Quote
Old 09-12-2018, 10:40 PM   #4
Thank you captain obvious!
Old 09-12-2018, 10:41 PM   #5
Thank you I will put it back to stock and set what happens
Old 09-13-2018, 09:59 AM   #6
No prob bob
Trx Bronco ESC problem - Similar Threads
TRX-4 bronco needs some help! Jameshnsd Electronics 10 08-25-2018 10:28 PM
TRX Bronco Exocaged Traxxas TRX-4 13 07-20-2017 07:16 AM
