09-12-2018, 02:25 AM | #1 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
| Mamba Monster X and Bowhouse Low CG battery tray
I've had the Mamba Monster X for some time but have been stumped to find a decent mounting place as the original ESC position would be too tight and I need the rear ESC mounting place for a fulll-sized shift servo, again still in the planning stage. My original thought was to fabricate a bracket in front of the steering servo but I had never got around to doing this. Having recently bought the Bowhouse battery tray I got that installed the other day and the rig had been sitting without the body for a few days while I patched some body cracks sustained in a 30ft rollover. I noticed the ESC while taking out some E6000 glue to coat the drywall tape and decided to take it out and look again at mounting options. As soon as I looked at the rig I noticed that the forward section of the new battery tray is quite flat and tried the size to find that it could have been made for the ESC. The ESC will be little higher than stock but it will be on the center line and wiring will be very easy. I'll be getting a small hole punch to make two holes in the 3M dual lock tape that I will be using so that I can easily access the two forward mounting screws in the battery tray and cut the shape to suit as the rear part of where I will be mounting the ESC has a recess. Pictures in a few days when I get it put together. |
09-12-2018, 03:07 AM | #2 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: Mamba Monster X and Bowhouse Low CG battery tray
Sounds like a great solution. Post up some pix once you have it installed. :-)
09-12-2018, 05:00 AM | #3 |
Will do.
09-12-2018, 05:41 AM | #4 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
I had the Mamba Monster mounted on the battery tray in the Bronco up front, is a good location unless you want to lower the body further, in my case i'm using the Proline 4Runner body and it hits the ESC so i can't lower it further that what i wanted, so i relocated the ESC besides the transmission servo, also i don't have the nerf bars installed, maybe with the stock Bronco body clearance is not an issue, either way i would check first
09-12-2018, 09:05 AM | #5 |
Newbie Join Date: Apr 2018 Location: Usa
This is where my Mamba X is mounted. I just used some velcro. Make sure you keep enough room so you can get to the pinion gear.
09-12-2018, 10:00 AM | #6 |
RCC Addict Join Date: Jun 2016 Location: Germany
You may have a look at the crawler innovation Front Plate for the trx-4 http://crawlerinnovations.com/traxxa...ctronics-tray/ Gesendet von meinem Pixel 2 XL mit Tapatalk |
09-13-2018, 05:42 AM | #7 | |
| Re: Mamba Monster X and Bowhouse Low CG battery tray Quote:
Photos soon. Last edited by bbrigg; 09-13-2018 at 05:45 AM. | |
09-13-2018, 05:48 AM | #8 | |
09-13-2018, 06:45 AM | #9 | |
Gesendet von meinem Pixel 2 XL mit Tapatalk | |
Tags |
3m dual lock, bowhouse battery tray, mamba monster x |
Mamba Monster X and Bowhouse Low CG battery tray - Similar Threads | ||||
Redcat gen 7 pro sport low center gravity battery tray mod | shenlonco | Scale Videos! | 0 | 07-30-2018 06:52 PM |
New competition low CG battery tray | SMALLVILLE | Traxxas TRX-4 | 16 | 02-21-2018 05:46 PM |
