Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: HH Revolver issues in a TRX-4
Old 09-30-2018, 03:01 PM   #1
Default HH Revolver issues in a TRX-4
OK, I know tons of ppl have put these into their TRX-4, what am I missing here?
Holmes Hobbies Revolver 540, 1800 kv, going into a TRX-4. Never heard of anyone needing spacers or anything?
First attempt at trying to put pics on here, hopefully it works....
Well, seems it didn't work, let's try this...
https://photos.app.goo.gl/bNsKD1ffJajJXKqz8
No idea if pics are working...but here is the issue in a nutshell..
The shaft on the motor seems way too long, it actually extends out past the plastic cover/mount and is impossible to mount up correctly. The flat part of the shaft begins at the gear, making proper mesh impossible.
It's like I need spacers?
Never heard of this issue before.
MODC is offline   Reply With Quote
Old 09-30-2018, 04:55 PM   #2
Default Re: HH Revolver issues in a TRX-4
Try contacting them. Its likely the shaft is out of spec. You could grind or cut back the shaft. Just take precautions not to get the filings in the motor, use cardboard or a plastic bag. It's a great motor, torquey and easy to maintain. Don't let this oversite get you bummed it's a relatively easy fix.
Sent from my SM-N960U using Tapatalk
crazy_eddie is offline   Reply With Quote
Old 09-30-2018, 04:58 PM   #3
You can also put more of a flat spot on the shaft . A Dremel or similar rotary tool with a cut off wheel is ideal for this situation.
Old 09-30-2018, 05:18 PM   #4
Already sent him a msg via his "contact us" form on his website....will see what he says, and assume he will want to see the pics. I'm thinking spacers might be easier than the dremel, or, a replacement, although I'm also in Canada, which may complicate things....
Could you see the pics using the link?
Old 09-30-2018, 05:34 PM   #5
I was able to see the pics using the link. They have good cs, but sometimes can be terse. Good luck!
Old 09-30-2018, 07:03 PM   #6
First, reverse the pinion on the shaft so it is oriented with the set screw away from the motor housing. Then once you have the pinion properly lined up with the spur gear you can trim off the excess shaft so it fits under the mount cover.
BTW, Once it is installed be prepared for the most annoying noise you can imagine.
Inspector86 is offline   Reply With Quote
Old 09-30-2018, 07:18 PM   #7
Originally Posted by Inspector86 View Post
Once it is installed, be prepaired for the most annoying noise you can imagine.
Hell, I want one just FOR the sound!
2mtech is offline   Reply With Quote
Old 09-30-2018, 07:33 PM   #8
Be careful what you wish for!
Old 09-30-2018, 07:56 PM   #9
Ahhh, never thought of reversing the pinion. I'll wait until after the weekend just to see what HH says before I start cutting stuff....
As for the sound, I know they are...umm...unique...wonder if on board sound would cover it....lol
Old 09-30-2018, 09:31 PM   #10
I absolutely love mine, in a Bomber - the 1800kv version, running 4S and 3S...
I'm actually fine with the sound, and it smooths out the faster it goes.
I don't have an interior, so mine is exposed - let it sing out!
durok is offline   Reply With Quote
Old 10-01-2018, 04:59 AM   #11
How do they stand up in dirt and stuff? I had my local HS really try to talk me out of the revolver. His view was it would not last at all because of dirt getting in it.
Old 10-01-2018, 03:36 PM   #12
Did this, worked like a charm!
Old 10-01-2018, 04:03 PM   #13
I had mine at the beach last week and it definitely was exposed to sand but after a quick blast from the compressor it was back to normal (it had a little squeek to it before)
Its always spinning so it tends to be the cleanest thing on the truck on the outside at least. Anyway I wont personally be too worried about it cause it can be torn down and cleaned but no one really wants to do that with a brushless motor.
And on the sound, its really not as bad as the videos make it sound.
HumboldtEF is offline   Reply With Quote
Old 10-01-2018, 04:38 PM   #14
No...I don't mind the sound at all.
Old 10-01-2018, 05:40 PM   #15
This summer in Texas we had a looong dry spell - the limestone bluff I did a lot of running at was total moon dust - like talcum powder...
No issues at all.
Think of it this way - when it spins it blows everything near it clean!
When I get home from a couple of hours of running it, I just blast everything out with compressed air from my Metro DataVac de-duster:
https://www.bhphotovideo.com/c/produ...EALw_wcB&smp=y
Best money I ever spent - never buy compressed air again, and way better for the environment, mine is several years old and I use it at least every week for cleaning all sorts of stuff.
I do make certain I blow into the Revolver's "cylinders"...
BTW - don't let your LHS talk ya out of stuff they likely don't understand - Outrunners have been around for many, many years.
They are great for many applications!
Old 10-01-2018, 05:55 PM   #16
I think I've seen you post this up before and it always makes me chuckle because I have a vintage data vac from the 80's, its probably not up to the task anymore though but one thing thats definitely better on the old one is the font, lol
Old 10-01-2018, 09:18 PM   #17
Hey, they're STILL "Made in the USA"!
HH Revolver issues in a TRX-4 - Similar Threads
HH Revolver S Stubby issues infodragon Electronics 35 04-02-2015 06:09 AM
esc issues or elec issues camogonewild Newbie General 5 03-11-2014 11:19 AM
HH Revolver ABOW Electronics 1 02-25-2010 06:57 AM
Revolver Q cembom Tires and Wheels 0 07-20-2007 02:28 PM
