10-10-2018, 12:40 PM | #1 |
Quarry Creeper Join Date: Aug 2018 Location: calgary
| Stock ESC removal
The stock trx4 esc has its wires run through a small plastic retainer right below the diff lock servos, its tight with all the wires . Do i need to remove the the servos to get my esc wire out or is it possible to slide it through? Thought i would as before i perform this task tonight. any other tips for replacing the esc and steering servo before i dive in? Thanks |
10-10-2018, 12:52 PM | #2 |
Pebble Pounder Join Date: Jul 2013 Location: Germany
| Re: Stock ESC removal
The servo holder is loosened with two screws, that's fast and simple. I replaced the ESC with a 1080, getting the XL5 out was the simplest part. The 1080 has a bit short cable and needed more work. |
10-10-2018, 01:34 PM | #3 |
Newbie Join Date: Jan 2018 Location: Lincoln
No need to remove the servos. Will be a little easier though if you unbolt the receiver box from the chassis. |
10-10-2018, 01:40 PM | #4 |
Thanks i see that the 1080 wire is short, guess ill use a extender on it.
10-10-2018, 01:50 PM | #5 |
Rock Stacker Join Date: Aug 2018 Location: Central Wisconsin
I had to remove the Rx box to get mine out but not the servos. Worked out ok because I had to turn the Rx box around for my new wire running layout anyway. My YouTube channel https://www.youtube.com/channel/UC9c...rIucM37i_nx3aw |
Stock ESC removal - Similar Threads | ||||
Stock TF2 Leaf Removal | YDAZOPEN | RC4WD Trail Finder 2 | 6 | 02-17-2017 09:06 AM |
stock Dingo wheel removal! | silversweater | Tires and Wheels | 6 | 02-19-2013 07:10 PM |
Stock ESC and 3S | zjguy721 | Axial Wraith | 1 | 02-27-2012 09:13 AM |
Li-po with stock esc | P1choco | Axial AX-10 Scorpion | 7 | 01-07-2009 09:10 AM |
esc fan removal | grob23 | Electronics | 2 | 06-30-2008 01:41 PM |
