Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Cheap light kit for Defender not working as intended
Old 11-01-2018, 07:14 AM   #1
Default Cheap light kit for Defender not working as intended
Hello, just bought the classic 20$ kit for the defender that you can find on Amazon/Banggood/AliExpress,
works as intended when I connect it to a ccpm servo tester, but when I hook it up to the actual receiver with the included Y cables the indicators blink randomly, the reverse light stays always on and the stop lights don't work, doesn't seem to be getting the signal from channel 2 and a dirt signal from channel one. Tried recalibrating the esc, changing drive mode, turning off Tsm, switching y cables, all with no luck. Everything on the board is connected correctly, anyone knows what's wrong?
Thanks
RCPawel is offline   Reply With Quote
Old 11-02-2018, 01:45 AM   #2
Default Re: Cheap light kit for Defender not working as intended
Sounds like a problem with power supply or loose plugs to me.
You have 6V max, i.e. stock ESC and Servos?
Tried another set of Y cables? They're pretty thin and should be replaced anyway.
The servo tester puts out 5 or 6V? Try one that has the same as the system, maybe there's a bad solderjoint on that $1 board and it just overvolts.
amigaman is offline   Reply With Quote
Old 11-02-2018, 05:11 AM   #3
Everything stock, the servo tester is connected to four AA batteries but works the same also with three, using the same Y cables.
Old 11-02-2018, 01:04 PM   #4
Do you have another RC system to try, preferably not Traxxas?
I have tried the thing in my Defender, but thrown it out because of weird functions. But it did work as intended, i just didn't like it.
My guess is your main board is broken, but maybe someone else has another idea.
Old 11-02-2018, 05:07 PM   #5
No other RC, just the one Defender.
Old 11-04-2018, 05:08 PM   #6
I bought the same kit, but never fitted it. It's destined for the dustbin.
crazee horse is offline   Reply With Quote
Old 11-22-2018, 09:15 AM   #7
Bought another one from the Injora Aliexpress store, this one is the original one and works, the other one was a knockoff.
Old 11-22-2018, 12:09 PM   #8
Could you elaborate how they were different?
Or is it just the software?
Old 11-22-2018, 09:12 PM   #9
They look the same, but you can tell that one is a knockoff of the other: "MODE." instead of "MODEL", wrong code on the back of the little pcbs, bad soldering, different fonts, etc.
Old 11-23-2018, 06:51 PM   #10
Ah ok.
Mine says Model, so i got an "Original", cost just 15 Euros for complete Set (without Rock lights and Lightbar), but still unusable.
Cheap light kit for Defender not working as intended - Similar Threads
In Stock - New MyTrickRC Attack LED Light Kit w/ 5" Light Bar for TRX-4 Defender! RPP Hobby RPP Hobby 1 10-11-2018 12:32 PM
Cheap amazon light kit 83trekker83 Traxxas TRX-4 9 09-16-2018 02:40 PM
Larry 8 LED Pocket Work Light as cheap scale light bar spoo76 General Scale Talk 8 12-15-2014 06:38 AM
Axial light kit not working? aircruiser Electronics 2 03-10-2013 03:29 PM
