11-04-2018, 04:31 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| TRX on a diet
My c2 Trx need to sheed some weight above the axles. But there's not a lot potensial left, without going for chassis swap. Converting the trans to a single speed would help, but the love the possibility the get extra wheelspeed. A nice bl combo would solve that, but that's not on par with my budget right now. Anyone else done some weightloss on their Trx? Sent fra min FRD-L09 via Tapatalk |
11-04-2018, 05:54 AM | #2 |
Newbie Join Date: Jun 2015 Location: Littleton
| Re: TRX on a diet
How important is waterproof to you? You could always ditch the receiver box. Beyond that I think you are close to your limit.
11-04-2018, 08:07 AM | #3 |
| Re: TRX on a diet
Not ready to ditch the wp reciverbox yet i think... A new chassis is the way to go, but have not found the right one yet. Sent fra min FRD-L09 via Tapatalk |
11-04-2018, 08:29 AM | #4 |
Newbie Join Date: Oct 2018 Location: US
| Re: TRX on a diet
Have you added weight down low? Have you lowered your ride height? Do you have a low weight, low cg body? Doesn't look like their is much left to do for lightening the top side of the chassis/internals. If you are competing, be careful if you change the chassis, make sure you stay within class rules. And get yourself some stainless hardware, those are some rusty screws! Good luck! Sent from my Pixel 2 XL using Tapatalk |
11-04-2018, 10:05 AM | #5 | |
| Re: TRX on a diet Quote:
Sent fra min FRD-L09 via Tapatalk | |
11-04-2018, 05:05 PM | #6 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| Re: TRX on a diet
Would you be shedding that much weight with a chassis swap ? Also the receiver box ? Really ? Talking grams max. Hardly worth the bother.
11-05-2018, 03:56 AM | #7 | |
Pebble Pounder Join Date: Feb 2014 Location: Canada
Agreed your saving a minute amount of weight...if your keeping the defender body you need to shed off the body were you can which is pretty much that anchor of a.tire out back and get your unsprung weight up using brass parts such as samix sells. Although I haven't added any brass down low I bought the spare tire delete/ roto pack mount from.knight custom. Even just doing that helped my max angle climb and side crawl. That tire and mount it's on is heavy. | |
11-07-2018, 03:22 PM | #8 |
| Re: TRX on a diet |
11-07-2018, 05:43 PM | #9 |
| Re: TRX on a diet
I was about to say some of the same stuff Nate already said. Go back to stock shock towers (they're plenty strong BTW), remove the deans to deans adapter/sandwich from the Hey OK controller and solder in your connection. Cut down your battery tray, surely you dont need all of that material. pair it down to just the needed mounting points and the bare minimum for holding the battery and cut off the rest. Eliminate the switch on the 1080 ESC, cut the wires and solder them together (it will always be on with a battery plugged in). Shorten any wires that are longer than needed. Shock tower braces/cross pieces can be lightened by drilling holes in them. You say you want to keep the receiver box which I understand, but in the picture you have the seal/cover removed so right now its not sealed up anyway. Just throwing that out there. |
11-08-2018, 10:16 AM | #10 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
| Re: TRX on a diet I believe it could be programmed with the card but the button beside the on/off switch is used for initial setup and calibration so I think I'd leave that.
11-08-2018, 10:26 AM | #11 |
| Re: TRX on a diet
I'm sure you could shave off a good bit of weight by moving to a 540 sized motor. Looking at some weights of generic motors, a 540 sealed can is about 2 oz (56g) lighter than an equivalent 550. With the weight reduction that has already been done, I wouldn't be too worried with motor heat.
11-08-2018, 12:07 PM | #12 | |
The alu battery tray is made from 0.5 mm alu plate, and is a lot lighter than stock plastic battery tray. It also put the battery lower than with the stock tray. I run 1300mah batterys, and there is not room for much bigger. But it’s possible to remove so metal from it. The wireing could need some tidying, so there is some grams to shed there. The proline commanche body is cut and quite light, with a low cog. I run SSD portal covers up front and som lighter no name portal covers in the rear. My TRX does do well in comps but there always room for improvements. I find it to heavy on loose surfaces. If there’s grip it does very well. | |
11-08-2018, 01:55 PM | #13 |
Rock Stacker Join Date: Oct 2018 Location: Nor Cal
| Re: TRX on a diet
I considered the same diet plan for my ten plus pound Defender. But then it’s the detail that made me love it in the first place. I bought a TRX4 Sport instead. Its everything it sounds like you want your Defender to be become. Just a thought Sent from my iPhone using Tapatalk |
TRX on a diet - Similar Threads | ||||
CR-01 needs a diet | mulepic | Tamiya CR-01 | 5 | 07-06-2009 08:47 AM |
betty's on a diet | colonelangus | Chit Chat | 8 | 01-28-2008 03:25 PM |
do you think she needs to go on a diet | Will | Chit Chat | 8 | 07-30-2005 04:04 PM |
