Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Cheap metal driveshafts???
Old 12-04-2018, 08:40 AM   #1
Question Cheap metal driveshafts???
Looking at the underside of my rig. I've noticed my stock driveshafts have taken a beating and should be replaced soon. I can pick up a new stock set for $8. I'm also seeing some cheap metal ones when i search on Google. Has anyone tried any of these? Are they worth the $17- $25 for them or should i just get another stock set till i can drop the $$$ on a crazy priced $70 set? Thanks for the advice. Have a great day!
AnimalHippie is offline   Reply With Quote
Old 12-04-2018, 09:14 AM   #2
Default Re: Cheap metal driveshafts???
I have a set of these on the way:
They have a pretty scale looking design, the universal joints tend to be stronger than CV style joints, and the shafts are splined instead of hex or D shaped (stronger, less slop). They seem to check all the boxes for good shafts but I'll have to see how testing goes.
svt923 is offline   Reply With Quote
Old 12-04-2018, 10:26 AM   #3
I went the SSD route for my Defender. I've heard of length issue with the front hitting the t-case but I assume that's on the Bronco idk. Anyway... I haven't had any issues at all. I did use some graphite to insure that they moved in/ out without binding as they weren't as smooth initially as the stock plastic ones.
$29 front/ $39 rear so I guess they weren't as cheap as I'd thought.
high plains drifter is offline   Reply With Quote
Old 12-04-2018, 10:34 AM   #4
I used this set and work perfectly, just make sure u get the right length for rear for either 12.8, or 12.3 wheelbase front is same length on both.
Sent from my LG-H873 using Tapatalk
Exiwolfman is offline   Reply With Quote
Old 12-04-2018, 07:36 PM   #5
I got these YR's on ebay for $30 for the set. They're made for the Defender so I had to cut down the center section on the rear shaft.
I greased mine, then cut a couple of small lengths of silicone tubing and slipped over the splines to seal and center things.
dr frankenstyle is offline   Reply With Quote
Old 12-04-2018, 10:40 PM   #6
these two points should be on the same line otherwise the output would not be in sync with the input..
pourMoneyIntoSea is offline   Reply With Quote
Old 12-05-2018, 06:25 AM   #7
Does it surprise you that a company that doesn't actually give a crap about RC didn't bother to install their product properly in their own pictures?
Old 12-06-2018, 02:50 AM   #8
yes but even rc4wd makes similar mistake..
https://store.rc4wd.com/Rebuildable-...le_p_3921.html
