Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: BowHouse Injection Molded Low CG Battery Tray at RPP
Old 12-30-2018, 03:42 PM   #21
Default Re: BowHouse Injection Molded Low CG Battery Tray at RPP
Installed mine today. very easy installation. the battery does sit a lot lower. won't know till tuesday how much it helps
sgtlt is offline   Reply With Quote
Old 11-07-2019, 08:05 AM   #22
Hey - I'm in the midst of a TRX kit build and I'm installing one of these as part of the initial build. The version I got is the injection molded, and it comes with a 2nd part, as backet for... well I don't know what.
It's not part of the original 3D printed version and doesn't seem needed for the install. But I'm not a fan of *I dunno parts* so I'm trying to figure it out
You can see the bracket in the product shots here:
https://www.amainhobbies.com/bowhous...waAnUSEALw_wcB
Anyone know? I'm assuming it's not needed for a TRX-4... but why included it and have the costs associated with it then
SlidePanda is offline   Reply With Quote
Old 11-07-2019, 08:08 AM   #23
It replaced the rear cross member if I remember correctly. Gives more clearance for full size packs.
Sent from my Pixel 2 using Tapatalk
brimdogg is offline   Reply With Quote
Old 11-07-2019, 08:33 AM   #24
Ah, I suspected it might be a brace, but my line of thought was it was a supplemental one, not a replacement.
Taking a look, you're 100% correct. The bolt spacing is the same as the rear cross member, and my 5000 mah pack won't clear the stock cross member.
Thanks!
BowHouse Injection Molded Low CG Battery Tray at RPP - Similar Threads
Mamba Monster X and Bowhouse Low CG battery tray bbrigg Traxxas TRX-4 8 09-13-2018 06:45 AM
New competition low CG battery tray SMALLVILLE Traxxas TRX-4 16 02-21-2018 05:46 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
