12-16-2018, 08:02 PM | #1 |
RCC Addict Join Date: Mar 2011 Location: easton
| c0bra’s trx4 bronco build
Like the tittle says I finally bit the bullet and bought a traxxas. Despite not agreeing with traxxas on the legal side of things, which I won’t mention my opinions on, I finally caved in and got a trx4 Bronco. I’ve always liked the look of these since they were released, but the long arm kit being available just made me want one even more. So 6 days ago I bit the bullet and picked up a trx4! I finally ran it for the first time on Friday since I borrowed a nimh battery from a coworker since I don’t have a single battery with the stupid traxxas id connector. The thing was not running right, I’m assuming it’s my own fault since I didn’t read the manual and I’m not familiar with the esc and all of the functions on the transmitter. After work that day I went to my lhs and picked up the lift kit for this thing! Now this build may be in the wrong section so please move it if it is. I am not going to be building it as a full on scale rig. It’s going to be a bit of a mud truck inspired mall crawler. It is going to be loosing the 2 speed transmission as I’ll be locking it in high gear, not sure how yet. I’ll also be locking the rear diff, most likely with a locked up spool. I will be keeping the selectable front diff and the fourth channel will be used to power a warm 8274 winch that I don’t have for it yet. Other than the 1 servo for the front diff, all of the traxxas electronics are going. It’s getting a sensored brushless system (not sure what as of yet, and I’m not a fan of sensorless), servo is being replaced with some sort of savox or protek, and the rc/tx will be replaced with a sanwa mt44 and rx481 receiver. Other plans that I haven’t mentioned are ssd bumpers front and rear, powershift rc light kit, ssd or vp 2.2 rims, some sort of ci foams and some sort of 2.2 pit bull tires. Ill also be replacing the plastic portal cases with either locked up or ssd cases Sent from my iPhone using Tapatalk |
12-16-2018, 11:41 PM | #2 | |
Pebble Pounder Join Date: Nov 2018 Location: Wilmington
| Re: c0bra’s trx4 bronco build Quote:
Welcome to team Bronco! Will be following your progress. | |
12-17-2018, 03:18 AM | #3 |
| Re: c0bra’s trx4 bronco build |
12-31-2018, 04:38 PM | #4 |
I’ve got the front axle back on the truck with a savox 1230 servo in order to handle 2.2s. I’ve also picked up a castle slate 2850kv combo which will be run on 3s. I’m going to try the stock pinion first Ive rigged the transmission to stay in high gear as well. I have also ordered a locked up spool and f/r link mounts. I will also be ordering locked up portal and diff covers for both the front and rear Sent from my iPhone using Tapatalk |
01-02-2019, 01:43 PM | #5 |
does anyone know for sure if the locked up aluminum portal covers will fit their steel portal knuckles and steel rear drive housings? Sent from my iPhone using Tapatalk |
01-12-2019, 12:22 PM | #6 |
Finally an update! It is now sitting on its own suspension once again and its new wheels! The front and rear axle have almost all of the upgrades locked up rc offers. It’s got the locked up diff covers, fi spool in the rear, link mounts f/r, c hubs, and steel portal cases, except the covers are aluminum. As far as electronics, it’s got a savox 1230 with an axial clamping horn, castle mamba esc and 2850kv crawler motor. Receiver is an airtronics rx481. This will probably mostly be run on 3s Sent from my iPhone using Tapatalk |
03-28-2019, 08:46 AM | #7 |
I have the rear bumper coming in on monday for this and will hopefully have time to get the electronics for this thing finished so i can run it on saturday. its supposed to be 71 here!
c0bra’s trx4 bronco build - Similar Threads | ||||
bilinvic's TRX4 Bronco Build | bilinvic | Traxxas TRX-4 | 107 | 02-28-2020 05:32 PM |
c0bra’s d4 rwd rc4wd hilux drift build! | c0bra | Non Crawler RC's | 41 | 01-22-2020 10:03 PM |
c0bra’s f350 build- back from the dead! | c0bra | Axial SCX10 II | 34 | 03-03-2019 12:10 PM |
Scoobs TRX4 Bronco Build | Scoobarooo | Traxxas TRX-4 | 7 | 07-16-2018 10:14 AM |
