TRX-4 Bronco on the way, what else do I need to buy I ordered the truck today, now I need to figure out what mods are mandatory to enjoy it. Along with the truck I purchased a HW 1080 ESC, I figured it’ll be better than the Traxxas one and has more amps to run a better steering servo without a separate BEC. I need to select a steering servo, I’d prefer to go budget but will buy something like a Savox 1230 ($70) if needed. I’m used to the hitek 7955 on my Bomber, so I don’t want it totally underpowered. Obviously a metal servo horn to match. I want to get a smaller battery to mount up front, I’ll convert to Deans plugs like my other rigs. I was looking at the $20 Holmes motor, but I’ve had great luck with the Traxxas 21T on my Bomber so I’ll run it for a while. Other than a servo, metal horn, and smaller 3s battery, what else do I need right away? Or what spare parts should I have on hand? |
Re: TRX-4 Bronco on the way, what else do I need to buy Quote:
I have been happy with the 20kg servos that you can readily find on Amazon and eBay. Beyond that, the sky's the limit for add-ons, but nothing I'd say is required. Sent from my Pixel 2 using Tapatalk |
Re: TRX-4 Bronco on the way, what else do I need to buy Nothing really needed to enjoy it. Just get out and use it. If something breaks upgrade it at that time. I just put my 2nd 1080 ESC with a HH Trailmaster 21T in my Bomber and it's a blast. I'm also running a 1080 on my 8x8 and it was good it's first run out. |
The micro servos don't like any voltage over 6 volts if you decide to try to throw more power to the steering servo. |
Re: TRX-4 Bronco on the way, what else do I need to buy I would definitely install a Castle Creations BEC PRO 20A SWITCHING REGULATOR to run the servo and other accessories. |
Re: TRX-4 Bronco on the way, what else do I need to buy This one has been working well for me... 3S 3500 mAh 30c Lipo - Helios RC I’m running a castle brushless combo and I’ll be out for 3 hours on one pack without hitting the lipo cutoff. |
Re: TRX-4 Bronco on the way, what else do I need to buy Front tray. There are some indents in the tray that it sits on top of, but it fits. A little dremeling gets it lower. |
Re: TRX-4 Bronco on the way, what else do I need to buy I honestly dont know why you people buy something RTR then ask what you need to buy. Its RTR, and as for buying a new ESC and motor without even trying the stock one is simply laughable. The xl5hv is a great ESC as is the motor, I've had mine for over a year and am.only just looking at replacing the 21t with another. Even my steering servo has been fine as I'm not one of idiots who thinks that a good servo means you can turn hour wheels whilst stationary. I don't know why most of you don't just buy kits from the off |
The only good thing about the xl5hv is that it comes with the truck. RTR =/= ready to kick ass. For a lot of us 125 oz of torque and an esc with a 1amp BEC just isn’t going to cut it. If it makes you happy then hey good for you but no point in getting all salty about someone you don’t even know having an upgrade esc on hand for his new truck. |
This is my third RC vehicle this go around, my previous two were both RTR and needed something replaced in the first 3 battery packs (3s). I would’ve purchased kits, but they weren’t available when I got my Axial rigs, and the Traxxas TRX-4 Kit is identical to RTR but without a body (the RTR Bronco is the cheap way to buy the body). Your comment about idiots who turn the wheels while stationary is ridiculous. Power steering in my 1:1 vehicle will turn the tires when stationary, I don’t see why that’s an unrealistic ask on a scaler. |
Re: TRX-4 Bronco on the way, what else do I need to buy Give it a shot out of the box for a minute. It’s solid. Plan to have some upgrade parts ready and add them in when something breaks or you notice a shortcoming. Number one in my book is a steering servo.... I was lucky and my Bronco steering service lasted almost 2 minutes. Garbage. |
What is laughable is someone criticizing others for requesting upgrade advice, while having no direct knowledge of the upgrades being discussed. The XL5 is most assuredly not a "great" ESC! If I'm being very optimistic, it is at best an OK ESC. With a 1 amp BEC the XL5 is weak which Traxxas is very aware of and is why they released the 2262 BEC as a crutch for it. Add any sort of extra electrical load and the XL5 overheats rapidly, ask me how I know. For the same cost of the XL5 you can buy the HW1080 which still is not a great ESC but it is orders of magnitude better than the XL5. If you are happy with your weak 1 amp XL5, then I'm happy for you. But there are so much better options out there for the same money that you are missing out on. If your stock electronics are in fact a year old as you claim, trust me, you will be replacing them soon and I hope you are not so closed minded as to ignore the HW1080, HH Trailmaster Sport 550 21T and maybe the Savox 1230SG as replacements. |
Re: TRX-4 Bronco on the way, what else do I need to buy I just installed a hi-torque servo in my Sport that’s capable of 400 oz at 7.4v. I would like to make the best of it. Options were to buy a $22 Castle BEC, or a 1080 ESC with program card for $40. Having had experience with Traxxas electrics, I opted for the 1080 ESC which has been a proven commodity on the forums here. It’s switchable from 6-7.4v, with no need for a seperate BEC. It’s therefore a cleaner / easier option. No extra wires to route and sort, no hunting for a good place to mount a BEC out of harm and waters way, etc, etc, etc. If the box stock rig works for you, that’s great. Others enjoy the process of improving their rigs and the respective performance. It’s not your $, it’s not your rig. Why let it chafe you!? |
Mounting the BEC is very easy and an enjoyable experience. It's not hard to hide wires and make the electronic layout look good. |
Also, I didn’t say I planned to add one later. I said I would add one If and when I deemed it necessary. I literally have one sitting in my electronics parts drawer. I have no worries about running the servo and a couple light bars off the 1080 either. |
Re: TRX-4 Bronco on the way, what else do I need to buy I’ve got the Kit, my son has the Sport. Replace the steering servo ASAP - his died at an all day RC trail event and made for a frustrating day (didn’t have a spare with me). I’d recommend: - cheap $20 servo from the “what’s the new cheap servo hotness” thread. that’s all we run and they are fine - Traxxas metal servo horn for TRX4 (it’s like $7) - HW1080 .. |
