New trx-4 bronco owner with a ? So I just got one of these over Christmas and noticed something odd, maybe just to me. When locking the diffs It goes from all open, to front locked with rear open, to all locked. I wanted to kinda change things around. I wish I could get it to operate like this, all open, to rear locked with front open, to all locked. I switched the two micro servo plugs on the receiver thinking that might work but it just changed the order of operation 180 instead of what I wanted. Does anyone know if this is possible or why it was designed like this. In 1:1 offroading we tend to start with all open diffs, then lock the rear when it gets a little worse, then lock the front when it gets really bad. That's just what me and my buddy's do. |
Re: New trx-4 bronco owner with a ? The lockers on my 1:1 rig are independent, I find I use the front only locked for crawling up obstacles more often than I want the rear locked too. Sometimes having the rear locked causes there to be too much traction and it sends the nose skyward as a rear tire drives itself into a hole. I tend to use the rear locker independently going fast on dirt or sand, the truck drifts better with the rear locker engaged. In these TRX-4 rigs I think I will prefer how it comes where I can just lock the front independently but not the rear. |
Re: New trx-4 bronco owner with a ? Quote:
ch4: reverse ch5: normal operation at transmitter: position1: all open position2: real open, front lock position3: all lock you should set them to: ch4: normal ch5: reverse then the operation at the transmitter would be: position1: all lock position2: real lock, front open position3: all open |
Re: New trx-4 bronco owner with a ? I have mine set to 1:rear lock 2:both lock 3:front lock So far my favorite setup, I don’t care about both open diffs. Works great for me. Sent from my iPhone using Tapatalk |
Re: New trx-4 bronco owner with a ? This video will show you how to do: 1. both open. 2. rear lock. 3. both lock. I prefer both diffs open the majority of the time. https://www.youtube.com/watch?v=aT24MGifqW0&t=5s |
Same vid I used to. I just did it along with the video. Sent from my iPhone using Tapatalk |
Re: New trx-4 bronco owner with a ? Thanks guys, I'll give it a try. |
