08-26-2020, 09:09 AM | #1 |
Newbie Join Date: Aug 2020 Location: BE
| Problem with hyrax 1,9 on trx6
Gents , I installed proline hyrax 1.9 tires on 2.2 beadlocks with crazy crawler wp foam. Now the problem is that the tires toughing each other at the back wheels of the trx6 The hyrax is a 4.73 (120mm) tire vs stock 4.60(118mm) Could it be the foam that stretches to tyre to big ?or any other ideas? Thx Bart Verstuurd vanaf mijn SM-T813 met Tapatalk |
08-26-2020, 10:54 AM | #2 |
Rock Stacker Join Date: Jan 2018 Location: Green Bay
| Re: Problem with hyrax 1,9 on trx6
It's either the foam or the 2.2 wheels expanding the Hyrax too far. I had Hyrax 1.9's on mine without issue (Proline 2 stage foam and Gmade AR beadlocks - both 1.9). I'd think your foams could be trimmed down a bit to get you some clearance. I've never mounted 1.9 tires on 2.2 wheels so I'm not sure how much of an effect that has on the tires o.d. |
08-26-2020, 11:07 AM | #3 | |
| Re: Problem with hyrax 1,9 on trx6 Quote:
The crazy crawler wp foam is very firm and dens structure .maby they strech the tire to far . I will compare against the stock foam Verstuurd vanaf mijn SM-T813 met Tapatalk | |
08-26-2020, 03:38 PM | #4 |
Quarry Creeper Join Date: Aug 2020 Location: Springfield
Might be able to trim them but wouldnt you lose the grooves around the outside? Spacing the axles a little looks like a nightmare. How bad is the running? Is it just the very center of the tread? |
08-26-2020, 10:18 PM | #5 | |
I order the proline dual stage to have a alternative . Should be deliverd today so i can compare Verstuurd vanaf mijn SM-T813 met Tapatalk | |
08-27-2020, 09:55 PM | #6 |
Ok i found what was wrong . The beadlocks are 2.2 , the foam 1.9 The inner ring streches the foam to far out and puch to tire to expand. I trimed the inner hole to 2.2 and it fits now . The only thing is that , if you ttined the inner jole a bit out of centre , the inner ring will whoble the tire a bit . Grtz Verstuurd vanaf mijn SM-T813 met Tapatalk |
Problem with hyrax 1,9 on trx6 - Similar Threads | ||||
OS's TRX6 | OSRC | Traxxas TRX-4 | 22 | 11-03-2020 12:27 PM |
Trx6 | michaeltncrawler | Tennessee | 5 | 07-04-2020 05:58 PM |
Got a new TRX6 today | gcurtis2121 | Traxxas Crawlers | 6 | 02-12-2020 09:52 AM |
TRX6 New Color | Rockin140 | Traxxas TRX-4 | 1 | 12-02-2019 12:44 PM |
