01-10-2019, 07:51 AM | #1 |
Newbie Join Date: Nov 2018 Location: Clermont
| Trx4 Bronco- Foams for Hyrax preadator compound?
Hi, I’m new here and just a couple months in crawling. I have a Bronco with brass portal covers and knuckles. Also have the lower shock mounts. Pretty heavy. I also placed sticky weights under the front small battery tray. I ordered ssd steel beadlocks and 1.9-4.19 Hyrax preadator compound tires. Are the stock foams good? If not what foams should I use and size? I heard to go soft up front and firm in rear. Proline 1.9 dual stages? |
01-10-2019, 08:20 AM | #2 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Trx4 Bronco- Foams for Hyrax preadator compound?
If it were me I’d go with these... Lil Probably comp cut inner, medium outter in rear and soft up front. I have the dual stage proline XL foams in the 4.75” predator hyrax and they work well, for what it’s worth. |
01-10-2019, 08:38 AM | #3 |
Just found out they are not 4.19 they are 4.73
01-10-2019, 08:52 AM | #4 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Proline 2 stage foams. |
01-10-2019, 09:16 AM | #6 |
Proline two stage foams are better, but I'm not sure if they offer them in 4.19 yet.
01-10-2019, 09:41 AM | #7 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: Trx4 Bronco- Foams for Hyrax preadator compound? They don't, which absolutely boggles my mind with the tiny-tire craze. If they produced some 4.19" foams (single and dual stage), they'd sell like hot cakes. Missing some major sales here.
01-10-2019, 10:08 AM | #8 | ||
| Re: Trx4 Bronco- Foams for Hyrax preadator compound? Quote:
These are 4.15 but they have them listed as for their class 1 tires. X2 about the Proline dual stage for the hyrax though, I’m very happy with them in mine. Just giving him options. | ||
01-10-2019, 10:11 AM | #9 | |
That spec is definitely wrong haha. The tires listed are their Class 2 tires. Sent from my iPhone using Tapatalk | |
01-10-2019, 10:13 AM | #10 |
That’s weird, the description is definitely for class 2 but then they have this... Specifications: Height: 4.15" (105mm) Width: 1.60" (41mm) Outer Thickness: 0.75" (19mm) Looks like an amain error? |
01-10-2019, 10:15 AM | #11 | |
https://www.prolineracing.com/insert...am-inserts.asp | |
Tags |
hyrax tyres, trx 4, trx4 bronco |
Trx4 Bronco- Foams for Hyrax preadator compound? - Similar Threads | ||||
PL Hyrax stock foams or CI foams? | Rekreant | Tires and Wheels | 22 | 05-31-2018 11:04 AM |
What CI foams for hyrax? | Mikeinsocal | Axial RR10 Bomber | 30 | 10-05-2017 09:53 AM |
