01-13-2019, 07:49 AM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: Cumming
| Best battery location, setup?
So I have had a Defender since they were released. I have just run the stock location with a 5000mah 3s since day one. But it’s time for a new battery and I’m thinking it’s a good time to consider battery location as well. What’s the consensus here on the best setup? Bowhouse? Bronco front mount? Another option? |
01-13-2019, 07:56 AM | #2 |
| Re: Best battery location, setup?
There's no best. Everything is a compromise. A forward mount will be better for vertical climbs. A lower mount will be better for side hills. Here's my opinion. Some people are using small packs up front in front of the servo. Too small for large batteries and the weight too high. Bowhouse gives you a lower center of gravity, but it moves the weight rearward which will hurt in climbing hills. If you install this tray you'll surely have to add weight up front. The stock battery is a good compromise. |
01-13-2019, 08:13 AM | #3 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
I run 3s 2650 and a 3s2200 I get about 90 to 110 mins low gear crawl time out of them without lights running. I also have a 3d printed lower battery tray. I noticed a big side hill improvement over stock battery tray. I also have a good amount of weight up front. My rig is a little more front weighted then I like. So the battery being low and to the rear actually helps me when going down hill. Personally I don't like the front tray. Just too much weight up high. I would go with the bowhouse tray if it was me.
01-13-2019, 08:35 AM | #4 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
I just put a BowHouse in my rig and it seemed to improve everything... up, down and side-hillin'. Even the 5000+ 3s batteries drop down enough that it seems to more than make up for the 1-in. rearward move. My buddy put one in his too, and felt the same about it. He ordered 2 more for his other rigs. I really like the upgrade. |
01-14-2019, 03:18 PM | #5 | |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
| Re: Best battery location, setup? Quote:
There is always a compromise. I think the stock location is the best balance in this truck. Sent from my SM-N950W using Tapatalk | |
01-16-2019, 11:26 AM | #6 |
Pebble Pounder Join Date: Oct 2018 Location: boise
| Re: Best battery location, setup? |
01-16-2019, 12:18 PM | #7 |
Rock Stacker Join Date: Jan 2019 Location: Salt Lake
Heres what I did with my TRX4 Sport...Battery sits about a low as you can get it, weight is a little more forward, and counter balanced. Simply remove the battery tray chop the ends off and then mount them to the chassis at the width of your battery. Also had to trim the arm shorter that secures the battery. And moved a couple other things around...really like where the esc sits now, super easy to power on/off without having to remove the body shell. Receiver is velcroed to the Savox servo which elimintes the need for an extension wire. Last edited by RustyTaco; 01-16-2019 at 12:32 PM. |
01-16-2019, 12:28 PM | #8 | |
01-24-2019, 05:33 AM | #9 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
Here’s my take for what it’s worth. The 2 best ways to improve the stock suspension setup on the TRX-4 are to move weight down and add some weight up front. Our battery tray significantly lowers CG with only a minimal rearward shift (depending on what size pack you run). Overall stability, especially on side hills, is much, much better than stock. I also like running 80mm shocks instead of the stock 90mm. You still get plenty of suspension travel, and the truck is much more stable. With those changes, I saw no need to add a bunch of brass down low, but everyone has opinions on those. Either way, adding weight up front also helps on steeper climbs, and there are several ways to do this. I chose to do it with a metal front bumper on my 110, and it helped a lot.
01-25-2019, 03:16 PM | #10 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
03-07-2019, 05:39 AM | #11 |
Quarry Creeper Join Date: Jul 2011 Location: ireland
bump
05-09-2019, 03:31 AM | #12 | |
Quarry Creeper Join Date: Jun 2013 Location: Australia
Sent from my SM-G950F using Tapatalk | |
05-09-2019, 05:53 AM | #13 |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
On a Sport, battery forward mounted on a Bronco front battery plate! Just yesterday I transitioned from the kit's ~50/50 weight distribution to 62/38. Using a 109g 1400mah battery up front. I was running the Bowhouse battery tray before that. The difference was huge. I made other small changes to get to that distribution but since you asked about batteries I'll stick with that. Don't just think about battery placement, think about weight distribution. (BTW, I got three straight hours of crawl time using MambaX and 3800!)
05-09-2019, 06:06 AM | #14 | |
It is good to install if you run full size stick packs but if you use smaller packs, you don't really need to install it. | |
05-09-2019, 08:16 AM | #15 |
Rock Crawler Join Date: Jun 2009 Location: UK
I use a 1500mah 3s lipo in between the front fenders. Works great. (sorry about the mobile footage!) |
05-09-2019, 08:24 AM | #16 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
^^ nice line and climb! Sub’d I use a small pack up front as well. |
05-09-2019, 09:29 AM | #17 |
Newbie Join Date: Oct 2016 Location: Innsbruck, Austria
05-09-2019, 10:39 AM | #18 |
I'm using a 3S 1400mah with a MambaX and 3800. I got over three hours straight crawl time last night.
05-09-2019, 10:44 AM | #19 | |
Are you just straight crawling or do you go trailing too? | |
05-09-2019, 11:59 AM | #20 | |
Quarry Creeper Join Date: Aug 2017 Location: KY
Best battery location, setup? - Similar Threads | ||||
Battery location | stobert2012 | RC4WD Trail Finder 2 | 3 | 09-28-2016 07:35 AM |
battery location? | JS412 | Axial SCX-10 | 6 | 04-21-2011 05:19 PM |
battery location | brandon17 | Losi Mini-Rock Crawler | 6 | 06-24-2010 01:59 PM |
Battery location | abbott90 | Losi Mini-Rock Crawler | 3 | 02-18-2009 05:22 PM |
Battery Location help. | Kingofthehill | General Crawlers | 1 | 03-07-2007 12:43 PM |
