01-26-2019, 12:21 PM | #1 |
Newbie Join Date: Sep 2017 Location: Canada
| Spektrum Dx5 locker set up
Anyone know Spektrum Dx5 setup's? I have AUX 2 and 3 programmed to button's E and F. Got everything working the way I want with the exception that the lockers will not remain locked, I have to hold the button to keep them engaged, as soon as you release the switch, it disengages. Every button/switch on the Dx5 is a 3 way switch, with a center, forward and back position, that self centers back (They are trim switches). How do I fix this? I have the 2 speed tranny servo hooked to button G, it is a simple push button, and it works great. |
01-26-2019, 02:26 PM | #2 |
Pebble Pounder Join Date: Sep 2016 Location: Rio Rancho, NM
| Re: Spektrum Dx5 locker set up
Interested in this as well Sent from my iPhone using Tapatalk |
01-26-2019, 03:29 PM | #3 |
I hope the DX5 is the same as the DX5R, thats what I'm looking at. From the Aux Assign screen you can select the Aux channel and adjust its setup button E only works as a 2 way switch and its only option is to be momentary (turns on when you push it, turns off when you let off) for this button you'll want momentary inhibited this way it will alternate between your 2 positions and hold position when you let off the button. Button F has a bunch more options but you'll want 2 position selected up top. I'd probably use cyclic (active) because this button is a bit harder to push back and forth and with cyclical active you just push this button again to get to the other point/setting. Momentary needs to be inhibited for the same reason as with button E. Last edited by HumboldtEF; 01-26-2019 at 03:32 PM. |
01-26-2019, 04:43 PM | #4 | |
| Re: Spektrum Dx5 locker set up Quote:
I have NO idea why, but when I first tried setting it up, I did not have the "Cyclic" option, when I went in to follow the steps you posted, it was there. Thanks for the help! | |
06-08-2019, 12:42 PM | #5 |
Rock Crawler Join Date: May 2013 Location: Uniontown
How did you disable the trim adjustment? Sent from my SM-G950U using Tapatalk |
Spektrum Dx5 locker set up - Similar Threads | ||||
Spektrum DX5 Rugged | JatoTheRipper | Electronics | 271 | 12-02-2021 12:44 PM |
IN STOCK NOW the NEW Spektrum DX5 Rugged Transmitter! | RPP Hobby | RPP Hobby | 0 | 01-07-2019 11:34 AM |
NEW Spektrum DX5 Pro In Stock!! | RPP Hobby | RPP Hobby | 2 | 07-30-2018 09:12 AM |
Spektrum DX5 | Kanine38 | Electronics | 1 | 09-07-2010 05:12 AM |
new spektrum dx5, with traxxas xl-5 esc, motor? | drnedatsnov | Electronics | 2 | 01-31-2009 03:48 PM |
