03-13-2019, 08:51 AM | #21 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Danza builds a submudder
Indybama that’s a great idea. I just got some lexan glue that dries clear as well. I think I’ll give that a shot on the tailgate. Not at all. You’re right on topic and its helping me with tire decisions. |
03-13-2019, 03:01 PM | #22 |
Rock Stacker Join Date: Mar 2010 Location: Fargo
If you do plan on running in a lot of mud I recommend one of these motor covers. I’m also running an alloy motor mount to help keep the motor cool since the cover only allows so much air flow. https://www.outerwears.com/proddetail.asp?prod=202450 |
03-13-2019, 04:16 PM | #23 | |
Newbie Join Date: Sep 2017 Location: Canada
| Re: Danza builds a submudder Quote:
No inner fenders to worry about...but you will need to be very careful on body selection. Sent from my SM-G955W using Tapatalk | |
03-13-2019, 06:06 PM | #24 |
Newbie Join Date: Dec 2018 Location: New Hampton
Your rig looks solid...very nice
03-18-2019, 10:36 AM | #25 |
MODC I agree with yotadude looks great! Thanks for the pics. My build has stalled out because of work and a busy weekend. Finally getting settled on a paint scheme (I think) and ordered the first upgrades (YR axle housings). Have the tires cut and siped similar to BMOWs tip. Now I just need to build it... Last edited by Topher Builds; 03-18-2019 at 10:40 AM. |
03-18-2019, 10:44 AM | #26 |
^^"Like"! I guess this is how I'm going to have to like from now on since the button is gone forever! Sad Tires look good Danza! Sent from my SM-G930V using Tapatalk |
03-25-2019, 03:15 PM | #27 |
I planned on keeping it stock, kept telling myself that, but these are going to look nice underneath with the paint scheme I have in mind. Everything else is still in the box, hoping to get started this week or next. |
03-25-2019, 03:23 PM | #28 | |
03-25-2019, 05:18 PM | #29 |
“Like” Lookin good Danza! I may have to score some of those YR axle housings. |
03-25-2019, 06:10 PM | #30 |
Something wicked this way comes... |
03-26-2019, 05:51 AM | #31 |
I need to send my Canyon Trails out to one of you guys with the FREAKISH level of patience it takes to cut and sipe them! LMAO!
03-26-2019, 06:36 AM | #32 | |
Nice choice with the wheels. Axles look cool too. Looking forward to seeing this build progress. Quote:
Same here! Canyon Trails are good tires are they come so I'm sure this makes them better. | |
03-26-2019, 09:21 PM | #33 |
Thanks dudes! I finally made some progress and got the transmission and chassis together. Also got the shocks filled up. Fenders are the wider TRA8072, not the narrow. They’re a little bit too wide but won’t require much trimming to fit under the sport body. Axles, electronics, and paint up next Haha, this was a two day task for me and done mostly while listening to conference calls. It was a process for sure. |
03-26-2019, 10:11 PM | #34 | |
03-27-2019, 06:37 AM | #35 |
They shipped wide fenders with a Sport body Danza?
03-27-2019, 07:46 AM | #36 | |
| Re: Danza builds a submudder Quote: | |
03-27-2019, 09:14 AM | #37 | |
| Re: Danza builds a submudder Quote: I had ordered them separately. After that thread where it was discussed that the narrow fenders didn’t cover the sport body very well, I decided to go with these for max coverage and to see how much trimming is needed. Got the rear axle built last night. Stuffed with Lucas red n tacky #2. Getting closer to being a whole turck | |
03-27-2019, 09:30 AM | #38 |
Build is looking good so far! Them YR axles look awesome. I ended up using the same inner fenders. After a little trimming on the sides and front they fit really well. If you look closely at the pics you can see where I cut mine. The only difference is I cut/Dremeled the molded shock towers off and cut out for my Samix shock towers. |
03-27-2019, 09:40 AM | #39 |
How are your fenders attached to the chassis? I started to cut the set from my bronco once upon a time and realized that I had to trim off the mounting points because the new shock tower used the same holes. Looks good B! Clean trimming. |
03-27-2019, 09:54 AM | #40 | |
Thanks! It took awhile to trim out for the shock towers, but ended up turning out pretty good. I wanted the inner fenders, but didn't want to give up my Samix! | |
Danza builds a submudder - Similar Threads | ||||
Danza’s TRX4 update - Tacoma | Topher Builds | Traxxas TRX-4 | 29 | 10-01-2021 10:29 AM |
Danza builds a 10.2 kit | Topher Builds | Axial SCX10 II | 66 | 08-24-2020 02:32 PM |
Danza’s Origin | Topher Builds | 1.9 Scale Rigs | 41 | 10-20-2018 06:19 AM |
