03-17-2019, 06:31 PM | #1 |
Newbie Join Date: Mar 2019 Location: Never Never Land
| How many radio channels do I need?
I have a TRX-4 Sport kit coming that I will be building up soon. I plan on doing with a 2 speed transfer case upgrade to it. The kit states I need a 4 channel radio. I believe all I need is a 3 channel radio however. I have a 3 channel Traxxas radio with the thumb switch I was planning on using. It's identical to my radio for my TRX-4 Defender other then it lacks the switch for the locking diffs which my Sport won't have. According to my Defender manual the 3rd channel(aka thumb switch) is used to shift the transfer case. I think the 4 channel radio requirement is just an error on Traxxas's part. Am I correct in believing my 3 channel radio will work fine for me in my application? |
03-17-2019, 07:28 PM | #2 | |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| How many radio channels do I need? Quote:
I believe the 4th would be to run the lockers? | |
03-17-2019, 07:46 PM | #3 |
| Re: How many radio channels do I need? The 4th is for the lockers according to my Defender manual, this is why I'm questioning the fact that the 2 speed transfer case kit say's it requires a 4 channel radio. I'm not going to be using lockers, I'll be keeping the spools.
03-17-2019, 07:51 PM | #4 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
That 3 ch radio should work just fine, you would only be hooking up 2 servos and a esc so yeah I don't see a problem, I think you are right there is a misprint.
03-17-2019, 11:11 PM | #5 |
| Re: How many radio channels do I need? |
03-18-2019, 09:26 AM | #6 |
Quarry Creeper Join Date: Apr 2018 Location: US
Yeah, I see no reason to need more than 3ch for that setup. Sent from my Pixel 2 using Tapatalk |
03-18-2019, 09:30 AM | #7 |
This is what I was figuring, I just wanted to get some input from others. Thanks for all the replies. |
03-18-2019, 09:42 AM | #8 |
Something to think about. If you plan on running a servo winch off of your receiver at some point in the future, you may want consider a 4 or 5 channel. I like to run 5 channel or more so I can run a winch, lights, etc.
03-18-2019, 09:59 AM | #9 | |
| Re: How many radio channels do I need? Quote:
My goal is to make a hardcore scale crawler with this rig. My Defender will be the one that gets a winch and a bunch of other scale things added to it. It will be more of a trail rig. That will happen at a later date, my Sport build is killing my wallet already. | |
03-18-2019, 10:43 AM | #10 | |
Actually on page 5 the manual suggests a couple of Traxxas options for TX/RX. 6507R is a 4 channel TQi TX/RX 6509R is a 2 channel TQi TX/RX | |
How many radio channels do I need? - Similar Threads | ||||
Radio for 8x8...how many channels? | jamesbernatchez | Electronics | 2 | 12-11-2018 10:43 AM |
Radio with more then 8 channels | quart | Electronics | 8 | 03-05-2018 08:57 AM |
What radio and how many channels do i need? | bigwig | Electronics | 9 | 12-06-2015 11:10 AM |
Radio Channels | White Stripe | Superclass Crawlers | 2 | 11-14-2010 06:49 PM |
adding channels to a given radio | roadblock | Electronics | 32 | 08-29-2008 01:01 PM |
