Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: OS's TRX4 Sport Kit
Old 08-13-2019, 02:53 PM   #61
Default Re: OS's TRX4 Sport Kit
Originally Posted by Ncrooks89 View Post
Could you post a link for the front bumper? I can't seem to find that exact one anywhere.
GMADE BOM Front Bumper Parts Tree
soze is online now   Reply With Quote
Old 08-30-2019, 10:08 AM   #62
Thanks Soze!
Had a great afternoon of weekday crawling... headed out to Ringing Rocks park near Allentown. Fantastic place to wheel... it's claim to fame is it's one of the few places in the world with sonorocks. when you strike them with a hammer, they ring like a bell. Way cool! Turns out when you crawl on them, they just sound like rocks.
Basically the layout of the park is you walk in on a nice trail with lots of obstacles, then there's an enormous granite rock that makes a huge shelf/waterfall. Can climb all over the shelf, then head down along the creek. I had planned to take the BOM but I forgot about the ripped receiver wire. Knowing that the terrain was going to be rough, the TRX4 got the nod...
So the Sport got a nice workout. No changes since the last run with the exception of dialing back the drag brake 2 notches. Got it almost dialed, did excellent.
It's pretty dialed, but doesn't defy gravity. I tried though!
Lots of great rocks, we spent quite a bit of time just trying different lines up the various rocks. This one was very challenging on the left but we made it. Sometimes the OD gear hurts more than it helps. I was running OD and my buddy was not...I was hopping at times due to the different ratios and the hop would break traction whereas all 4 tires on his rig were digging smoothly. Something to think about...
Lots of great chains as well start on one rock, work over to the next.
Spent 30 minutes here, there's about 10 different ways to get up here and got all but one. The slope on the far right is possible, though the Sport's high COG thwarted me... Challenge for next time!
Finally made it to the rock shelf...hard to capture in pictures, but it's way cool. Mostly flat with a lot of horizontal fissures that are fun to get in and out of.
Coming out of one of the fissures..
At the far end, there's a shelf of about 4 feet. There's 2 lines up it - one through the creek, and one on the rocks. Sport made them both, which is the first time I've ever got up here.
The Duratrax tires did really well last time out, which was a bit wet. This time, it was dry and dusty and I think they could have been better. There's were spots where it should have gone up and over but it seemed to struggle. I'm going to bring some TSL's and Pitbulls next time, swap them around and do some back to back runs. Maybe I'm expecting too much, I don't know. Only way to find out is to do some back to back runs and see what happens. All in the name of science of course!
OSRC is offline   Reply With Quote
Old 09-21-2019, 09:20 AM   #63
Last time out running the Sport, it did well. Very well in fact. Only thing that was causing me concerns is it still wants to lift the nose a bit on inclines, and did some rollovers in spots where I didn't think it should. Basically, the COG is still somewhat high.
So when I saw these for sale, I decided to give them a shot. GPM hubs with multiple lower shock mounts... I figured it would allow me to lower the truck a bit and give me a more progressive angle on the shock.
Before... ride height shot. Moved my work bench outdoors for the afternoon.
Started on the rear axle first... everything went together fine, no issues. The modified hub is on the left compared to stock on the right. I ended up going with the middle hole on each as it lowered the truck about 10mm overall. Can see how much more progressive the shock angle is.
Rear complete! Easy peasy!
The smooth install came to a screeching halt in the front. C hubs look pretty cool!
Ruh-roh! They come with new stainless shoulder screws to replace the low energy Traxxas screw/steel sleeve combo. Great idea in concept, but the screw is 5mm and the C-hub is drilled for 6mm. Whoops. Completely unusable in the current form.
After taking many pictures and firing off an e-mail to GPM, I decided to see if I could make it work. The spacers included for mounting the shocks are 6mm in diameter and I found they fit right in. The Aluminum will wear quickly so it's not a permanent solution but it will keep me wheeling tomorrow... wonder if I can find some 3x6 bearings? hmmmmmm.... (EDIT - Found and ordered!!)
*sigh* ...... Not sure if the screws keep it centered or what, but there's a whole lot of vertical play going on here.
Dug out some washers and shimmed it out.
So it's ugly, but I got it mounted. Finally.
After ride height...Sorry, losing the light!
Came back in and took a flex shot. The truck now sits much lower overall - I'm hoping what I lose in clearance will be made up for in stability. I lost a bit of flex as well, but I think 2 tires is plenty. I'll find out tomorrow!
Old 09-21-2019, 09:29 AM   #64
JatoTheRipper's Avatar
That's a bummer about the front GPM parts. I've had hit and miss luck with them as well.
The rear parts are interesting and it's curious that they change the shock angle. I do really like that the truck sits lower though.
Can't wait to get back out there!
Old 09-21-2019, 09:57 AM   #65
Is there a way to lower the truck without losing flex? I like the look of the lowered stance much better.
Sent from my LM-G710VM using Tapatalk
MaX-D is offline   Reply With Quote
Old 09-24-2019, 08:02 AM   #66
Sure, just crank the spring collars up higher. Truck will sit lower.
So I sent an e-mail to GPMUSA, and no beuno. They said go to Asiatees.. Asiatees apologized and said the best they could do was a full refund. Decided to keep them and use some bearings to make them work. Buyer beware!
Anyway, gave it a good thrashing last weekend. Really, I beat the hell out of this truck and it just keeps coming back for more. I don't know that it is more capable per-se, but relocating the shocks has made it much more planted. The suspension is far less flexy and much more deliberate...all in all, I like it. Feels a lot more stable on the rocks.
BOM bumper comes in handy when you are navigating a boulder field.
This is a tough rock - got up both sides...coming up from the right is very steep and tricky. Never would have done this stock. Think this truck is finally dialed.
Found this massive boulder....super tricky to get up there, but we made it. Was running with a well tuned Enduro and kept up no problem. First time I've run with this Enduro that it has impressed me - it made some great lines.
Someone (Lisa Confina apparently) painted a boulder to look like the beach. I tried to go for a beach shot with the truck....not so much!
All in all, very happy with the Sport. Can't think of anything I'd change at this point other than messing with some tires. I don't think the Duratrax are bad per-se, but I think there's a bit more performance hidden in there. Oh, and losing the mirrors and snorkel as the catch on the rocks constantly! Scale looks are fine, but this is a performance truck.
Old 09-24-2019, 09:22 AM   #67
Nothing like signing your vandalism.
AsiaTees has always had great customer service in my experience as well. GCM not so much.
Some of those rocks are tricky so this truck is certainly dialed!
Old 10-01-2019, 08:57 PM   #68
So, little update: I'm missing some white bushings for my C hubs. That's where the fitment issue came in.
After many e-mails back and forth with Asiatees, I got nowhere. Best I got after showing them a pic of my parts and the picture of the parts on their website (Clearly showing the white bushings that were missing from my parts) is "This item is sold as the set pack seen on the photo, this will be how the same amount and screws been supplied. the item will not include any spacers in the pack which customs may need to purchase separately. "
I don't know what that means other than I won't be shopping there again. Too bad, good prices and some unique stuff that's hard to find otherwise. But getting screwed is unacceptable.
Anyway, I got some 3x6 bearings in the mail today, I'll fudge up something a little more permanent than a few 3mm screws spinning in some aluminum spacers. After 1 run, it's already got noticeable play.
Old 10-03-2019, 07:48 AM   #69
Came up with a pretty nice solution ...picked up some 3x6x2.5 bearings and some 3mm shims. It was tedious, but I shimmed the knuckles in the C-hubs, then used the bearings in the C-hubs. The steering overall is now slop free and way smooth! Still ticked I had to spend so much extra time on it, but it worked out good in the end.
Old 10-03-2019, 09:26 AM   #70
into the ether...
smog's Avatar
Page 4 is looking great! Got a bit of everything. Great pics(especially like the one that caught the spinning tires), excellent performance tip and a little Macgyver troubleshooting.
It’s helping get me stoked on my Sport build
smog is offline   Reply With Quote
Old 11-19-2019, 07:10 PM   #71
wyd
OSRC I always enjoy reading your write ups no matter what brand your working on. If I see you doing something I like to stop in and see what your up to. Very nice write up as always.
wyd is offline   Reply With Quote
Old 11-19-2019, 09:28 PM   #72
Thank you sir, very kind of you!
I've got updates, just have been a bit behind in posting.
Old 11-21-2019, 08:33 AM   #73
Been slacking lately... the Sport has been out on a few runs, I just haven't been posting any pics. I'm not hard on my trucks per-se, but this one takes any and all punishment I throw at it - it goes through some hardcore terrain and other than some serious body rash it has yet to give me any problems at all. The TRX4's are just tanks.
Last run I swapped over to some TSL's - the Deep Woods aren't terrible tires, but the TSL's simply have much more grip. It was a very noticeable difference. Basically this truck is dialed at this point. Haven't had to change a thing, just toss in a battery and go.
It's that time of the year again...leaf season. This is where portals come in so handy.
This spine rock is a great challenge, and the Sport just owns it. Have to come up the side, do a 90d turn up top and straddle the spine up and over. Again, portal axles and a lot of clearance helps a ton...
Been going out during the week - all the kids are back at school, so it's just the sounds of electric motors, bumpers banging off rocks, and babbling brooks in the background. Love this time of year!
Old 11-24-2019, 10:53 AM   #74
Beautiful scenery and a beautiful truck. Love the colors.
Sent from my Vivo XI+ using Tapatalk
mgputer is offline   Reply With Quote
Old 11-24-2019, 01:20 PM   #75
Great thread. Which swampers are those?
Your c-hub experience reminds me of getting a bunch of gpm parts for a ta01 and having to modify literally every item so it would work/fit. I see gpm hasn't changed inyears.
meatmonkey is offline   Reply With Quote
Old 11-25-2019, 07:57 AM   #76
Proline TSL's, G8 Compound. Best tires I run, hands down.
As a follow up, Asiatees did finally send replacement C-hubs. Took several e-mails and a few weeks, but they did arrive. Came in about 2 weeks ago, I was shocked actually. Totally forgot about them.
Old 12-18-2019, 09:02 AM   #77
Time for an update for the Sport. Been running good, wouldn't change a thing. That's when boredom sets in..time to shake it up a little.
Picked up the Bronco conversion parts... I regret selling mine, Absolutely loved the look of it. Jato laughed at me for selling my Bronco, then spending a fortune on the body to convert over my Sport. However, when it came time to cull the TRX herd a few months ago, the Bronco was the logical choice to sell - much more popular than the Sport, and holds it value better. I actually sold it for slightly more than what I bought it for, so I think it was the right call.
Anyway, a well used and abused Sport, Bronco body, fenders, body mounts and a few odds and ends to get started.
Goes quick, nice to have inner fenders again... They'll stay on regardless of body swaps in the future.
Traxxas doesn't include the light covers, they are sold separate. Really? C'mon, that's really nickel and diming.
Bought body mounts, but the body came with what I need, not to mention I found a couple in my parts box. Whoops!
Front torn down...I was debating going front motor as I have the GRC kit left over from my Defender, but left it stock for now. And I lie - I did add some HR weights up front since I ran it last - they are a bit heavier than the SSD's and I wanted a touch more weight
to help plant the front.
Boom!
Bumper and push bar, I added a servo guard in there while I was at it. Nice that the body comes with the push bar and spare wheel. For the price, it should!!
And the body drops right on... I'm not a huge fan of the black simply cause everyone has it, but it does look sharp! Body comes with both red and sunset decals. Not sure what way I'm going yet.
Of course, the SSD slot wheels are going on, they look perfect with this body. They needed a good cleaning, they were wet inside and the tires with caked with mud.
After some much needed washing and airing out, the tires went right back together. PL foams held up to the water pretty well, once washed and dried they felt good as new.
I like it....might have lost some clearance and maybe some performance, but damn, its a good looking rig!! Very happy with the change. I've got other trucks I can build up into performers, this one's going down the trail in style!
Old 12-18-2019, 09:40 AM   #78
Good! Now I have a reason to run my Bronco again. I really should get a Blazer body for it though.
Old 12-18-2019, 03:41 PM   #79
@OSRC, if you need the rocklight covers I can print you some and send them. I had the same issue and 3D new ones.
CarlC is offline   Reply With Quote
Old 12-18-2019, 04:30 PM   #80
Thanks Carl, I have some laying around. Appreciate the offer though.
OS's TRX4 Sport Kit - Similar Threads
OS's TRX4 #2 - Bronco OSRC Traxxas TRX-4 59 08-08-2019 10:21 AM
TRX4 Sport kit svt923 Traxxas TRX-4 265 06-27-2019 05:16 PM
2 speed conversion kit/activating servo in my trx4 sport ShotCrawler Traxxas Crawlers 2 12-03-2018 03:53 PM
Trx4 bronco with Sport body and traxxas lift kit Exiwolfman Traxxas TRX-4 0 10-13-2018 03:20 PM
Trx4 kit or trx4 sport mebeknob Newbie General 10 09-26-2018 11:38 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
