03-22-2019, 08:58 AM | #1 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Wiring nightmare solutions ???
Let's see some pics of what you guys did with all your wires!!! I'm trying to figure out what to do with my wire nightmare and need some inspiration. I have so much going on as for wires it's not even funny. It's very discouraging for me Everytime I try to attack this issue. I'm trying to fit a 6 or 8 channel (preferably 8ch) flysky Rx, CC BEC, Light controller, Rx bypass loop and all my servo wires (shift, lockers, esc) in somewhere that will still look good. Right now it looks like someone threw up colorful spaghetti under the body of my rig. I was thinking of getting a different RX box but having a hard time finding anything that will fit the 8ch Rx along with all the other stuff without ruining my COG. Any help, direction and solutions are much appreciated! Have a great day!!!!
03-22-2019, 09:04 AM | #2 |
| Re: Wiring nightmare solutions ???
Here's a pic of my nightmare. Don't mind the tape. I've been switching stuff around and using some leads to test stuff before I solder them permanently. Such a mess. Kinda embarrassed for you guys to see this, but maybe it'll help you understand my frustrations |
03-22-2019, 09:19 AM | #3 |
Here are pics of mine before I added the Traxxas inner fenders for my Sport body. It was a pain to get it tidy, but I'm happy with it.
03-22-2019, 09:24 AM | #4 |
| Re: Wiring nightmare solutions ??? |
03-22-2019, 09:30 AM | #5 |
Newbie Join Date: Feb 2019 Location: US
This was literally the reason I'm keeping the stock radio, reciever, and if I ever change the esc will keep the little traxxas red power lead. Was thinking of spektrum as I have a DX5C. Powering my 325oz. Servo with the traxxas bec that stays in the reciever box for a clean install and running traxxas light kit. Be interesting to see peoples solutions though! Sent from my SM-G960U using Tapatalk |
03-22-2019, 09:34 AM | #6 |
| Re: Wiring nightmare solutions ??? It is the Traxxas #3628 box. I use it to house my winch controller and wires. I use this style box in all of my rigs. It is sealed with an o-ring and comes with silicone grease. I have never had my equip. get wet with these. I buy these on Amazon.
03-22-2019, 09:43 AM | #7 |
RCC Addict Join Date: Sep 2017 Location: The OC
03-22-2019, 09:52 AM | #8 |
Here is a look at my VS4-10 wiring. I used the black mesh (can't remember the real name) to cover my wires before I zip-tied them.
03-22-2019, 09:54 AM | #9 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
I hid my wires best i could down in the frame rails. My rx box looks like a fuel cell that sits between the rear shock towers on my scx10ii. I dont have a good pic of my rx box. N im runnin a different batt tray as well Sent from my SM-J327VPP using Tapatalk |
03-22-2019, 09:58 AM | #10 |
I also use these to attach zip ties to. Sent from my iPhone using Tapatalk |
03-22-2019, 01:04 PM | #11 |
I'm rolling a Sporto, so a few less wires to contend with. But, I've found zip ties and heat shrink to be my best friend. My Baja Rey is loaded with accessory wiring, including an engine sound system. I just try and find the best routing and then work on making manageable loops, and then zip tie and secure them to anchor points. |
03-22-2019, 01:29 PM | #12 |
BTW - I "LIKE" many of the ideas above for wire/cable routing. Nice job guys! |
03-22-2019, 01:47 PM | #13 |
I'm really digging all these ideas! Have definitely helped my brain get to working. Now time to put some work into all these ideas. I'll probably place everything where I want it and zip tie it till I get another Rx box for the front. Guess I'll probably go with a 6ch flysky Rx cause I don't have room for the 8ch :-( even tho I'd like to have 8.
03-22-2019, 02:02 PM | #14 | |
| Re: Wiring nightmare solutions ??? Quote:
I can't find the dimensions of this box any where. Do you mind pulling L,W & H measurements for me? Kinda tight up front on mine with that nukizer body on it. | |
03-22-2019, 02:50 PM | #15 |
03-23-2019, 08:22 PM | #16 |
Newbie Join Date: Oct 2018 Location: US
One more recommendation, to get rid of the bunches of wire, make custom length wires. For $40-60, you can get wire, connectors, and the custom crimper tool. Crimper should work for both servo connectors and jst connectors. Sent from my Pixel 2 XL using Tapatalk |
03-23-2019, 09:18 PM | #17 | |
Have learned to solder too...but I always try to melt-down the motor terminals. | |
03-24-2019, 06:47 PM | #18 |
RCC Addict Join Date: Jun 2016 Location: Germany
If my electronic is settled and tested i do a custom wiring making my own cables, using a crimp tool from hobbyking. you mean you have a mess that's a mess 6 Ch RX (all used), Castle Link, Aux Wire, 2 RX Switches, power cable for motor fan and 3 custom Y cables for spliting channels. Still improvable but ok for now |
Wiring nightmare solutions ??? - Similar Threads | ||||
Wiring nightmare - Harness needed? | Truckmechanic304 | Electronics | 6 | 11-10-2016 03:41 PM |
RC solutions chassis | dostacos | General Crawlers | 3 | 06-02-2013 11:05 AM |
RC Solutions chassis | KRAWL | Axial AX-10 Scorpion | 5 | 03-01-2010 06:19 PM |
RC Solutions chassis- Anyone know/use it?? | Mayze | Axial AX-10 Scorpion | 11 | 03-01-2009 04:31 PM |
two CS80 servos = wiring nightmare? | shutupanddrive | Electronics | 0 | 11-29-2005 12:57 AM |
