03-30-2019, 10:42 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| GRC Motor mount
Anybody have any feedback on these? I finally shredded a spur gear and noticed a fair amount of F/R play in the plastic mount. https://rover.ebay.com/rover/0/0/0?m...2F142854773719 Sent from my iPhone using Tapatalk |
03-30-2019, 10:53 AM | #2 |
Rock Stacker Join Date: Apr 2015 Location: Uvalde
| Re: GRC Motor mount I love the front mount motor. I does take other mods to make it work proper. But changes a lot. Sent from my iPhone using Tapatalk |
03-30-2019, 11:29 AM | #3 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: GRC Motor mount
I have Just installed the grc one piece motor mount and it fits perfectly. Also gives the posibilty to check gear mesh properly. Gesendet von meinem Pixel 2 XL mit Tapatalk |
03-30-2019, 01:01 PM | #4 |
| Re: GRC Motor mount
I installe this one on one of my TRX4s which is the same as the GRC and it works OK but really did not add anything IMO. https://www.ebay.com/itm/3-35-Motor-....c100005.m1851 |
03-30-2019, 07:58 PM | #5 | |
Rock Stacker Join Date: Jan 2018 Location: Sulawesi
| Re: GRC Motor mount Quote:
The first is that it shrouds the grub screw on the pinion in some cases. Sometimes you can reverse the pinion to fix this but not always. The second is that the hole pairs are not as accurately spaced as they could be. I only noticed this when I installed a Holmes Hobbies Revolver motor. The longer shaft required a motor spacer so I bought the Yeah Racing set of three alloy plates. These have quite tight mounting screw holes and when using a 13T pinion I had to use a bit of force to screw in the mount screws as they were binding on the spacers. The holes for 9T and 11T were fine. I've gone back to the 9T as the low speed control is fantastic and wheel speed on 3S is still okay. I have ordered an alloy motor plate, using the standard shape, and alloy lower cover set that have a screw holding them together, Xtra Speed Aluminum Motor Mount Set Black For Traxxas TRX-4 #XS-TX28060BK. This looks like a good option and it will put the, admittedly minor, extra weight lower down. I'll let you know how it is when my order arrives. Sent from my LG-H870DS using Tapatalk | |
03-30-2019, 09:18 PM | #6 | |
Good to know. Think I’m hold off for a bit. Sent from my iPad using Tapatalk | |
03-30-2019, 10:08 PM | #7 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
I've had this one for several months and still working great. https://pulsar.ebay.com/plsr/clk/0/S...tw%3D%3D%22%7D | |
03-31-2019, 11:16 AM | #8 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
| Re: GRC Motor mount
I've been running one just like Inspector86 and CODYBOY's since last fall and mine works great too. I'm even running an 8T pinion and all it took was a little filing on the holes. For less than $20, I think it was money well spent. jim |
GRC Motor mount - Similar Threads | ||||
GRC motor mount? | number9 | Traxxas TRX-4 | 10 | 08-13-2019 07:17 PM |
GRC motor mount | m1009cucv | Traxxas TRX-4 | 8 | 09-25-2018 02:50 PM |
Hot Racing Motor Mount Hits Spur Mount HELP!! | RevoRacer | Axial AX-10 Scorpion | 3 | 05-08-2008 06:06 PM |
